Question about Kenmore Elite 45986 Front Load Washer
Washer will not turn on... - Kenmore Elite 45986 Front Load Washer
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Posted on Jun 22, 2009
My frigidaire front load washer stopped working mid-drain. Now the washer will not drain, fill, or spin. No error codes are displayed on the LED. When I set the washer to a given cycle, I hear only a...
It sounds like the pump has stopped and may have sucked a sock or rag into it. May need to pull the washer out, remove the back. Unplug the washer and see if you can manually turn the pump/motor belt. It could also be the motor but I would check to see if they turn. If not, remove the belt and manually try to turn each and see if they turn.
Nov 06, 2017 | Frigidaire ATF6000ES Front Load Washer
My blinker and washer fluid won't work on my dodge caravan
This sounds like the fuse for the turn signal/washer has blown. I've had a similar problem that traced back to the washer pump. Replace the fuse and just "bump" the washer switch. If the washer doesn't turn on, don't hold it on or it will blow the fuse again. You'll need to replace the washer pump. In the meantime before your pump replacement, your turn signals will work again.
I hope this helps! :)
Feb 11, 2010 | 2005 Dodge Caravan
My washer won't turn!!
Sir, first please confirm is your washer having any power. If not it will not function. Or you are trying to say the tub is not turning. If yes then reply me.
Thank you Sir.
Sep 21, 2009 | Tecnik TKL9260 Front Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Washer starts then stops how do you reset the washer
Try turning off the circuit breaker for 60 seconds and turning back on again. Then turn on washer.
Jun 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 05, 2009 | Garden
Sounds like the main control board instead of the interface. Remove top and locate CCU. Shold be on R side or rear at the top. Unplug all connections and replug. See if that helps. If it helps and it happens again, replace the board. FYI. Whirlpool electronics are horrible for loose connection problems.
Mar 18, 2009 | Whirlpool WFW8300SW
Kenmore Elite 45986 Front Load Washer Logo
216 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
