Question about Orion HCCA-D5000 Car Audio Amplifier
Why does my hcca 5000 esplight is amber and it powers on and subs play but when turned off protect mode lights come on?
steveswny
  • 32 Answers
SOURCE: orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Posted on Feb 28, 2009
leehumphreys
  • 38 Answers
SOURCE: noise when turn on and play music
Good chance that it is alternator noise mate, there is a little component that you can buy what you fit onto the alternator to stop unwanted noises feeding back threw the audio, ask in a car audio shop i would tell you the name i just cant remember it at all.
also check that all the earths are perfect, *bare metal* 80% of audio problems are due to a bad earth.
Posted on Apr 10, 2009
  • 122 Answers
SOURCE: when i adjust the controls on my orion2400 hcca
your amp is shorting internaly most likely from be handled rough the only thing i recemond is replaceing it cause it will fail completly it just a matter of time & it could be a fire hazared in you car
Posted on Jun 04, 2009
SOURCE: My Orion d-5000 amp which is wired to an Orion
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Posted on Jun 30, 2009
  • 7 Answers
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Posted on Sep 18, 2009
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
Amp has power, turns on with stereo, but sub isnt playing... all connections are good.. whats wrong?
if you have a protection light that is on it means the amp is in protection mode and wont allow any power to the sub this usually happens when the sub or wiring shorts out or if there is an internal failure in the amp or if its overheating. check the wires and connections and test your sub on another amp.
Dec 12, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My amp keeps going into some safe mode and red light blinks and stops base to my sub. I have it hooked up to 1 15.4 Orion HCCA.
The "safe mode" on your amp usually kicks in for two reasons - the ohm load on the sub is too low for the amp (presenting a "short" to the amp), or it's going into thermal protection because the amp is too hot. From your description, it sounds like there's a short in the wire, the sub's ohm load is too low, or the sub is partially blown.
If you have another sub or speaker, connect it to the amp's output and see if the amp still goes into protection mode. If the amp goes into protection with a known-good speaker, then there may be something wrong with the amp's power supplies. If the amp works properly with another speaker or sub, then I would check the sub that's causing it to short out.
You may also want to check whether or not the amp is over heating by just touching the amp when it goes into protection. If it's just warm, that should be ok - if it's hot, then it might be working too hard. In this case, you may need to check the input voltage (12-14VDC) and the size of the power and ground cables. If your ground isn't properly connected, it can cause weird problems like over heating, shorts, erratic behavior, etc...
Mar 04, 2010 | Orion HCCA-D5000 Car Audio Amplifier
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Problem w/ Orion HCCA - D5000 Amplifier
Try checking the wiring configuration from your sub to the amp, if the resistance is too low it can cause to go into protection mode or the amp is damaged and you will have to get it service
Jul 10, 2009 | Car Audio & Video
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Orion HCCA-D5000 Car Audio Amplifier Logo
44 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
