Bluestar split ac indoor unit making abnormal
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes unbearable after I go to sleep after I switch off all lights in my room. The noise can be explained as machinery like something is stuck in its fan. I am unable to sleep due to this. I have consulted bluestar people....they came ...cleaned indoor & outdoor unit and went....doesnt help...and as I explained that noise is more at night so they did not get it at day time... Thanks in advance..... My email is amaranup@gmail.com.
  • 2,133 Answers
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
Posted on May 07, 2014
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Posted on Jan 24, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jmgldsmth
  • 1869 Answers
SOURCE: ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
Posted on May 28, 2009
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Sep 16, 2015 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
My split a.c bluestar showing f8 What is reason
There is a fault in the temp sensor on the indoor unit that is working with the cooling unit.There could be a Freon leak check the pressers with the unit running. If low on Freon then look for leeks and make repairs. If psi is good then check temp sensor and replace if needed.
May 10, 2014 | Heating & Cooling
Blue star propane to natural gas
http://bluestar-store.mwrc.net/en/product.php?product_id=40188
That is the kit you need. Usually comes with step-by-step instructions on replacing the orifices, converting appliance regulator, setting damper, etc...
Jan 20, 2014 | BlueStar RNB48 (Gas) Kitchen Range
F8 dispaly error in blue star split ac
hello,
i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-
1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)
2> then check wheather the wire is in good condition or not means
is it working or not.
3> then clean the outdoor unit filters and coils,
4> and check the proper supply of electricity..
Mar 15, 2013 | LG LS-L1210CL Mini Split Air Conditioner
No spark and no power: Bluestar 36
Is there power at the outlet? I know that it is probably very hard to get to behind the heavy Bluestar, but it looks like you may have to pull the stove away from the wall and make sure it is still plugged into a working outlet. All of those stove functions are fairly separate, so to have all of them go out, you probably have a power supply problem. There may even be a break somewhere between the plug and where it splits off into the fan/light/ignitor parts.
Dec 08, 2009 | BlueStar RNB36 (Gas) Kitchen Range
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
