Question about Honeywell Rth110b Horizontal Digital Manual Thermostat
Network into household internet - Honeywell Rth110b Horizontal Digital Manual Thermostat
Where can I get an I.p. address for my tablet . Im not sure what happened , I put it back to factory settings and after that there was no ip address. Please help?
What most likely happened is when you factory reset the device, the wireless setup that you use to connect to the Internet was reset as well. You need to go into the wireless setup area and look for networks to connect to. The one that you use regularly (assuming you are where you use the device), should be among those listed. You then tell the device to connect to the network. This is where the device will ask you for the network password if it is a secure network (and most are). Once you input the password, then the network router will assign an IP address to the device and connect it to the network. After that you can access the Internet normally. If you don't know or forgot the network password, someone in the household (or business) should be able to provide it so long as you are authorized to connect.
Dec 11, 2015 | Sungale Tablets & eReaders
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
I sign in on play station home and it loads then suddenly I'm kicked and this error code pops up its getting really frustrating.
This is due to the internet connection to your ps3 being interrupted or too slow to register. Is your ps3 linked to the internet wirelessly? If so, try plugging it in directly with an Ethernet cord. Make sure nothing else in your household is using the internet as well. This will help the os3 to connect faster with the network.
Nov 29, 2012 | Video Game Consoles & Games
We cannot get internet through our Wii.
If you have wireless running in your household. enter your wii options the little icon the lower left hand of screen. Go to Wii Settings, screen over to the internet selection. go to the connection settings, select connection 1 wireless, and it should offer to do a scan. Find the signal with your information such as your network name. If you have a password on it while you are trying to connect enter your password and it should connect.
Feb 04, 2011 | Computers & Internet
How do i get wireless internet if i can't find the password to my household router
You can reset your household router back to factory specifications and then re-enable your password. There is asmall hole on the side of most routers that when a tooth pick or a straighten paper clip is inserted,and pushed for about ten seconds resets the router. Then you have to go into your router setup and re establish your password in order to protect your network. The information of how to do it is contained in your manual. If you do not have the manual, then visit the routers site on the internet and down load a new copy of the manual.
Dec 28, 2010 | Sylvania G-Netbook
My son can't connect to x box live, it keeps asking for the wpa key, what is this and where do I get it from?
Your WPA key is simply put, the password that protects your internet. (Wi-Fi Protected Access). I'm assuming you have a wireless internet and that is how your son is connecting to Xbox Live? (Unless he is mistakenly connecting to another wireless network other than your own.)
Someone in your household should know what the WPA key is, because it was the password set to protect your internet. (Most likely done so on a PC or laptop.)
So here are my suggestions:
1. Make sure your son is connecting to the right wirless network on his Xbox. You can do this by going to Settings --> System Settings --> Network Settings --> Configure Network --> Clicking A once you get to that Menu, and then scanning for Networks. Chances are you will get a few results. In order to connect to Xbox Live, you have to chose your wireless network.
2. If no one in your household knows the WPA key, I would suggest contacting who ever set up your internet, or another option would be to connect to Xbox Live directly, using the modem cable. (You would have gotten this when you originally bought the Xbox.) This can get pretty complicated however, so I would suggest trying to figure out the WPA key.
I hope I was of some help, feel free to contact me if you're still confused.
Jan 31, 2010 | Microsoft Video Game Consoles & Games
If I reset my d-link router will my household
If you set up your again with exactly as it was before the reset you (same WEP key, wireless network name) then your computers should just reconnect. If you're having to reset the WEP key, the worst that will happen is that you'll get a prompt to put in the new password the next time your computers try to connect to the wireless.
NB - performing a reset on your router will mean you have to set the thing up from from scratch so make sure you have your internet username and password to hand (if it's ADSL) and that you know what your old wireless network settings are before proceeding.
Dec 15, 2009 | D-Link AirPlus DI-524 Wireless Router
New dell studio desktop will not connect to internet with Vista
Turn off the Windows Firewall and the firewall software (Windows Live one care) and you should be able to connect to the Internet without any problems
Dec 27, 2008 | Microsoft Windows Vista Ultimate Edition
Honeywell Rth110b Horizontal Digital Manual Thermostat Logo
12 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
