Question about Epson Stylus CX6400 All-In-One InkJet Printer
How to extend the life of epson printer cartridges even after the exclaimation point comes on as ink is still in the cartridges
Use original product and select the larger black
Posted on Jan 28, 2015
eclark317
  • 159 Answers
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
  • 36 Answers
SOURCE: refilling ink cartridges for epson printer CX6000
You can purchase re-manufactured cartridges online from Re-Inks and Atlantic Inkjet. This is usually the easiest way to get them, if you refill them your self they have a better chance of leaking and ruining your printer.
Posted on Mar 21, 2009
  • 30 Answers
SOURCE: Epson Ink Problem on sx200 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-28
Posted on Sep 04, 2009
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Tip
Reset Epson printer ink counter and ink cartridge
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
  • Work directly with CSIC in EPSON Stylus printers cartridges.
  • Reset or rewrite any chip using special add on device.
  • Freeze internal ink counters.
  • Reset internal ink counters even with empty cartridges.
  • Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
  • Hot swapping of cartridges supported.
  • Resetting of protection counter (even then it is already full).
  • More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
Click here for the EPSON Ink Pad Reset Utility
on Jan 26, 2009 | Epson Stylus C88 InkJet Photo Printer
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson C90 failed to detect ink original cartridges
I guest, the problem is chip module attached on the head (housing). Need to be change
Hope could solve ur the problem
Rusdi
Mar 10, 2010 | Epson Office Equipment & Supplies
Epson Stylus photo R230 Desktop : Printer icon flashing with exclaimation mark `No Ink` changed Black Ink cartridge in printer , Red & Green lights on not flashing Please help.. how do you know which...
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Aug 31, 2009 | Epson Stylus Photo R300 InkJet Printer
Waste ink absorber full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Do vote if this helps ... Cheers :)
Dec 20, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus CX3810 replace ink box. will not let me print.
I'm sorry to say, but I just spoke to epson and the printer will not print unless all cartridges have ink. The black ink only option is only used to extend the life of color cartriges. Just another way for them to get you to buy things you don't need.
Dec 04, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Ink cartridges
didnt see any c46 listed on the manufacturer website. sure you put the right number down?
How old is this printer?
Oct 20, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
