Question about GPX D200B Player
Circuit of gpx dvr701 - GPX D200B Player
Sound but no picture on my GPX 32" model # TDE3274BUP what can I do to fix this? Please and Thankyou!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Jan 04, 2017 | GPX Televison & Video
Gpx 32 inch led hdtv have sound no picture
Jun 09, 2016 | GPX Televison & Video
How to get circuit board for gpx bd707b
i do not see manuals online for this item but here is there # 1-888-999-4215 - 8:30am-8:00pm CST, 7 days a week
Aug 16, 2014 | GPX BD707B 7 Portable DVD Player with...
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
Gpx users guide
GPX has multiple models. LBrown18062@hotmail.com
D108S GPX D108S: User Guide D1307 GPX D1307: User Guide • Specifications D1816 GPX D1816: Specifications • User Guide D1816SIL GPX D1816SIL: User Guide • Specifications D200B GPX D200B: User Guide D2816 GPX D2816: Specifications D2817 GPX D2817: User Guide • Specifications P PC308B GPX PC308B: User Guide • Specifications
Feb 04, 2012 | NEC Televison & Video
Audio no picture
do you get a splash screen when there is no Disc playing ( something that says something like DVD VIDEO). If not and the scren is just always black then it sounds like the backlighting circuit has failed
Mar 17, 2010 | GPX PD808B Portable DVD Player with Screen
Can u please help i need gpx 4500 detector service manual and circuit diagram
temporarly the following would gives some insights into GPX4500
http://demarcodetectorsales.com/html/minelab/GPX-4500.html
Dec 14, 2009 | Computers & Internet
Having problem with my gpx remote control for my
Try cleaning the remote, the button "5" could be jammed (disassemble the remote, clean the rubber pad(s) with buttons, circuit board AND housing, especially the holes through which the buttons protrude, there may be some stuff keeping the button sticked/jammed).
You can use ethyl alcohol for cleaning.
regards
3rq8 (Triarcuate)
Jul 24, 2009 | Televison & Video
Freezing
sounds like a bad solder joint that is cracked...as GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
Nov 27, 2007 | GPX DV7500 System
GPX D200B Player Logo
15 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
