Question about Coleman Heating & Cooling
Hot House My AC works great, cold air coming out of the vent (about 63*) intake working well also. (about 76* in the middle of the day) Think it could be the insulation?
  • 520 Answers
This is never an easy fix. Insulation is one factor but other things to look for is drafty windows and doors, wall outlet covers and seal the plumbing where it comes through the walls. I recently had the power co. come out and do an energy audit to find my houses weakest points of energy conservation. This is truly a great service. I have lowered my power bill by 23% and my house stays much cooler and my a/c comes on less in the heat of the day. Hope this helps. Good luck.
Posted on Jun 22, 2009
Montana ac problem
some external sensor has taken a knock etc
sounds like its not getting whats going on outside
or the evaporator has an issue with its drains
perhaps something in the air intakes
Dec 23, 2014 | 2001 Pontiac Montana
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Weak air conditioner air flow and very hot upstairs.
Check the fans are all working ok and make sure there isn't a louvre closed in the duct
May 04, 2012 | Heating & Cooling
I charged my ac last summer, worked great. This summer the 2 vents on the passenger side work great, very cold. The 2 vents on the drivers side blow air but not cold, just like the ac is not on?
One of your Actuators inside the dash that control the A/C Heat doors/ Baffles that open or close, to either give you hot or cold air has failed. Find and replace the failed Actuator and it should work fine.
Jun 24, 2010 | 2007 Hyundai Tiburon
Furnace does not work when windy outside. Has an electric ignite, it either won't kick on at all, or it just blows cold air. The slightest breeze will cause it to not work. When there is no wind it works...
The problem is withthe venting. Your vent pipe goes out of the house in such a way as to catch the air when it is windy and cause the pressure switch to cut out. The flame may only run for a short time, then shut down and then restart. The heat exchanger never gets hot enough to give you warm air.
Check where the vent pipes exit the house. Try adding on an elbow and turning it so that the wind cannot blow back the pipe. Turning it down towards the ground often is good. Make sure that the exhaust cannot recirculate back to the intake pipe also.
Also check that there is no water build up hanging in a pool where the vent pipe may have sagged a bit. this will make the pressure switch much more sensitive.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 11, 2009 | Coleman Propane Forced Air Heater...
In my 1998 Honda Accord Lx the hot air does not come out of the heater vents in the floor, the same is true for cold air in the middle vents on the dash. The side vents on the dash work fine.
In my 1998 Honda Accord Lx the hot air does not come out of the heater2_bing.gif vents in the floor, the same is true for cold air in the middle vents on the dash. The side vents on the dash work fine.
Dec 06, 2009 | 1998 Honda Accord
Air Conditioner isn't making the house cold at all
I'm pretty sure your low on freon have your pressures checked!
May 31, 2009 | Ruud UAKA048 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Air conditioning is blowing hot air, system fully charged compressor is woring
The problem is the venting door. There are vent doors that are used to switch between AC and heat. Some vehicles use a cable that opens and closes the vent doors, other cars use vacuum and some are electric.
Whatever the case may be, if you feel the cold on the tubes, then the AC is likely working, you have to get the vent door working
May 01, 2009 | Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
