Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where do the fuel lines hook up on 1993 gmc serria pick up
Need to know where on the throttle body fuels hook up witch is the in line for fuel
studio500
  • 36 Answers
SOURCE: need a diagram of the
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Posted on Apr 17, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
#1 Taper
  • 1040 Answers
SOURCE: where do the fuel lines go on a poulan 2375 wild thing
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 24, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
  • 2239 Answers
SOURCE: have replaced fuel lines but
There are three hoses on the machine, the hose from the tank with the filter on the end, connects to the fuel inlet on the carb, this is the inlet closest to the pump side of the carb held with a single screw, there is then a hose nearest to the metering dide of the carb, this goes to the short conection on the back of the primer, the suction side, the long connection on the back of the primer, the pressure side returns to the fuel tank, just remember the primer pulls fuel from the carb, and back into the tank, not the other way round, if you have connected them the wrong way, this will explain why it runs badly.
Posted on Mar 19, 2011
Testimonial: "thank you it sounda like the problem we could not find a diagram for the hoses "
Where is the fuel pressure sensor located on the 97 v6 gmc sonoma pick up
It is on the fuel rail It kinda looks like a top hat and will have a vacuum line running to it. Look around the throttle body area along the fuel rails.
Mar 01, 2013 | Cars & Trucks
1993 GMC Jimmy won't throttle up..changed fuel pump...sounds like fuel is running back into tank
Check fuel pressure regulator.Start engine hook fuel gauge to fuel line check pressure ready then pull the vacuum hose of the fuel regulator if pressure rises 5-10 psi then its good.
May 13, 2011 | 1993 GMC Jimmy
I have a 1993 gmc 2500 van with a 4.3 v 6 engine stalls will not start. get no fuel at throttle body inj. if I add fuel to throttle body van will start and run as long as I give it gas . when allowed to...
You must have a leak or one of the lines are clogged. The reason it stays running when your on the gas is because it keeps the fuel pressure up. Then when it shuts off it loses all pressure in the line and the pump cant handle the initial start with the leak in the line.
Sep 14, 2010 | 1993 GMC G2500
My 1993 GMC 1/2 ton truck stopped suddenly and will not start.
The inline will not work,it can not get fuel threw the fuel pump in the tank,the fuel tank has to be removed,and the fuel pump changed out.
Apr 12, 2010 | 1989 Chevrolet K1500
The truck idles rough when first cranked,also sluggish at certain speeds,like not getting gas .I've changed egr solinoid,and throttle body gaskets thought might be vacuum leak. Could it be the fuel pump?
it could be the fuel pump, fuel line, or a hose problem. try cleaning out the fuel line first and then see. any replace the fuel filter if it has one. if that does not solve the problem then best bet is a fuel pump issue
Jan 01, 2010 | 1993 GMC Sierra
2001 gmc sierra 1500 not getting fuel
remove fuel line from throttle body and have someone try to start. If no fuel is "shooting" out of line, there is a block. clean out line or replace.
Jul 05, 2009 | 2001 GMC Sierra 2500HD
What two coolant lines connect to the throttle body on a 3.1 multi port engine
There are no coolant lines connected to the throttle body, just the two fuel line. The high pressure side and low pressure side (Return line) and I believe the lines don't even connect to the throttle body on a multi port engine, the lines go to the fuel rails to the injectors.
Good luck
May 24, 2009 | 1993 Chevrolet Lumina
Wont start
fuel pump maybe
Mar 13, 2009 | 1993 GMC Sierra K1500
Hesitation
is it a throttle body or fuel injected?
Sep 02, 2008 | 1993 GMC Sierra
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
14 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
