Question about Air Tools & Compressors
Porter cable air compresser model cffn251t - Air Tools & Compressors
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: What is the difference between
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
  • Type numbers can be very different from brand to brand. Sometimes an entire type number is just one digit or letter, and sometimes type numbers are very long numbers or long combinations of letters and numbers.
  • "Type numbers" go by different names, depending on the manufacturer. Some manufacturers call them type numbers, while sometimes they are called the: engineering number, series number, or bar code number.
  • Some model types are only distinguished by the year of the model.
  • Type numbers can be very difficult to find, sometimes located on the inside of a tool's housing (like some Ryobi tools). Fortunately, most type numbers are listed on the name plate with the model number.
  • When a manufacturer does not anticipate redesigning a tool or machine model, the first type of that model often does not have a type number assigned to it by the manufacturer. Designs that follow the first type will usually have type number designations.
  • Some manufacturers do not use a type number system at all, and instead change model numbers for each new design. In this case, the model number is the only number needed to match the right parts to the tool or machine.
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
Posted on Jan 19, 2010
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
I too had noticed the heated compression rubber hose.. the older models for smaller united were made to last longer and used 1/4" copper tubing and flang fittings kence, less rubber seals to fail over the long run, although porta cable says the compressor has a three year limited warranty for this product.. Mine has started to leak just over a year and only used a few times maybe twice a month. So even ubder light duty this unit has failed not just the drain plug seal,, but internal seals inside the compressor. I have returned this ubit for a full refund. So to answer your question, "what would cause a rubber hose to get extremely hot" it is normal for all compression tubings and hoses to run hot to the touch when running long periods but it is also a problem when poor engineering and lack of quality components such as rubber seals fail and cause leaks and so causing excessive heat and internal damage to other seals under such extremes..May I suggest you contact porta cable and ask them about your trouble with the product and their three year limited warranty
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
PORTERCABLE COMPRESSOR
hi there,
there are considering factors to be check.the belt tension of the motor should be fitted between motor and compressor to avoid slip tension of the belt.adjust motor alignment.if still not compressing air
or lost compression replace piston ring.have a nice day dont forget to fix my rate/thank you
May 07, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Looking to buy a manual for a porter cable nail gun model # PORTER CABLE FN250B 3/4''-2 1/2'' 16 GAUGE FINISH NAILER
Go to Dewaltservicenet.com and type in your model number the manual is 13 pages long. If I have helped you with your request would you please rate this response accordingly. Thank you
Oct 10, 2009 | Porter Cable Air Tools & Compressors
My CFP6025VP Porter Cable Compressor doesn't build presure in the tank
You more than likely have a damaged compression ring. This is the ring that goes on the piston. Check to see if the cylinder is scarred also if the ring is bad. You should replace both the compression ring and the cylinder. Check with your Dewalt service center to see if you can puchase an assembly that has both. Also check your valve plate and make sure the fingers are ok. Sometimes a broken finger will give you the same result.
Sep 06, 2009 | Porter Cable Air Tools & Compressors
Belt sander 3x24 Porter Cable
Try some "Simple Green" concentrate cleaner, or the "Simple Green" barbecue cleaner in a spray can to clean the roller. Should not use a dremel as you probably know now because of damage.
Another good idea is to blow out the tool after each use with compressed air. An air compressor is a great tool for a lot of things!
May 30, 2009 | Porter Cable Cable Tools 3" X 24" Belt...
Air Tools & Compressors Logo
18 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
