Question about Hitachi Heating & Cooling
Indication E 6 in hitachi window ac
Model summer TM Compressor is not switching ON
2 Suggested Answers
  • 661 Answers
SOURCE: Model 38TDB - exterior fan
Hi Les,
You need to replace the contactors and check if it works fine , one of my friends had the same problem and replacement of the contactors or connectors was the solution.
Hope this helps ..:)
Posted on Jun 26, 2011
Know when a relay switch is damaged for a Suzuki xl7 2004
ok, this is easy ,really
  1. fuse are first
  2. blower in dash must blow, and A/C light glow.
  3. the compressor must spin (shaft) if not the clutch in front is not energizes or the belt there fell off.
  4. the high/low switch (Freon(tm) pressure switch up front ) must be closed, or the system shuts, down (saving itself)
  5. if you get this far, ask for help for next set of tests on the AC amp logic. ( 6 things that cause it to shut it all down)
  6. ask
Mar 02, 2015 | Suzuki XL7 Cars & Trucks
Engine quits when ac turned on compressor unplugged
Knowing make model and year would help. Most newer vehicles, 2000 and newer, will adjust the idle control up to compensate for the compressor engaging. Possible there is an issue in the idle air control valve or electrical circuit.
Mar 14, 2017 | 2003 Ford Focus
2003 Mini Cooper S A/C doens't work
Also, make sure the correct a/c buttons are depressed.
Recirculated air, a/c button etc. lower temp.
The AC will NOT blow cold if the radiator fan is not running....period.
Persue the fan problem FIRST.
I would try the least expensive thing first, the pressure switch. Pretty much everything takes a signal from it.
If the pressure switch circuit is open, the fan stays on. If the DME, gets no signal that there is pressure in the line (where the switch is mounted), you get no cycling at the compressor.
You will have to evac and recharge the system after changing the switch, which any decent shop can do.
Sep 18, 2012 | 2003 Mini Cooper
2003 mini cooper AC compressor doesn't run
indicates a low gas problem
have it properly diagnosed by an ac specialist shop
Oct 30, 2017 | Mini Cooper Cars & Trucks
The compressor will last a lot longer. Your problem is a very slow Freon/refrigerant leak from when the compressor was replaced. If you wish, you could put in a canister or 2 of refrigerant from an auto parts store, as a kit with the re-fill line, to make it work for a while. But eventually you're going to want someone to find that leak and repair it. Best of luck my friend.
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
1 ton hitachi window ac dimensions
quadricool sm)1.1 ton dimension is 660x430x805cm,
quadricool tm) 1.1 ton dimension is ,, ,,,,,,,,,,,,,,,,,,,,
Nov 09, 2010 | Hitachi Heating & Cooling
When I start the AC the power switch trips
change your mcb and checked your voltage and compressor
May 11, 2009 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
