Question about Casio fx-300ES Calculator
Solving -log need to 1x10^-14 / 2x 1o^-8
  • Casio Master
  • 7,993 Answers
0.5x10^-6. Better use the exponents rules.
Posted on Aug 27, 2014
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
OD
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
HOW TO CALCULATE 1O TO THE POWER -9.55
+/- 9 . 5 5 2nd [10^x]
The +/- key is just to the right of the decimal point key. [10^x] is on the LOG key in the center of the top row.
Dec 13, 2010 | Texas Instruments TI-30XA Calculator
My Acer netbook one freezes. PLEASE HELP!!!
First thing to do is to scan your system using some powerful antivirus program. Now fix a freezing computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Hope it would help you. Thanks
Mar 02, 2010 | Acer Aspire 1640Z Notebook
To solve the problem using log
Look the calculators has a default base 10 and you can't change it but you may learn this:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
so instead input log 8 base 2 you need to input log 8 / log 2
your example answer is about 0.919... if i get right what did you write.
Glad to help :)
Feb 21, 2009 | HP 33s Calculator
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
My calculator a casio fx-300ms can´t solve this
log is base 10 by default. You put in 2 (times) log 8.
Log (2) 8 is not the same as 2 log (10) 8. This is not a calculator issue this is your lack of understaing of log.
Mar 23, 2008 | Casio FX-300MS Calculator
Casio fx-300ES Calculator Logo
44 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
