Question about HP PSC 1350 All-In-One Thermal Printer
Hp 1350 gear reset - HP PSC 1350 All-In-One Thermal Printer
Cant find hp psc 1350 on list of hp printers
HP "series" numbering can be somewhat confusing, but Windows 7 does have the correct driver for your printer.
For the HP PSC 1350, you will need to use the 1300 series driver.
The 1310 series driver is for models numbered 131x (e.g., 1315, 1318).
Jan 25, 2013 | HP PSC 1350 All-In-One Thermal Printer
My printer (HP PSC 1350) says there is a paper jam but I have taken the paper out, taken the back off and there is no paper jam. Is there a way to reset it or something?
hi
unplug the printer from power source
open the upper cover
move the CR cartridge carfully at the right position look inside is there any broken pices
Oct 27, 2010 | HP PSC 1350 All-In-One Thermal Printer
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
I have refilled ink in the hp 1350 but the orange light is still flashing beside Check print cartridge and i cant print
Those cartridges have electronics inside to tell the printer when they are empty, there's no guage inside the cartridge. Online you might find ways to reset your cartridge, but the best is to buy a new cartridge.
Jan 10, 2010 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 Windows Vista Support
I would check the HP forums as a more likely place to find an answer to this question...check here
May 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Download free software for hp 1350 all in one printer
I want HP PSC 1350 soft ware free to down load, I have missplaced. I need this soft ware. Can you help me
Feb 23, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
