Question about iLO DVDR04
Does the dvdr04 record from the video input - iLO DVDR04
My ilo dvd R/P will not record and keeps saying invalid disk,
TILO DVDR04 PLAYER RECORDER THE DVD RECRDER IS IT SPECIFIC TO THE DVD RO4 CAN IT BE REPLACED WITH ANY PLAYER BURNER IT SEEMS TO PLAY NORMALLY.
Mar 08, 2010 | iLO DVDR04
Only view in black and white on my ilo DVD R04
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
May 11, 2009 | iLO DVDR04
Need a manual for an iLo DVD Recorder, Mod. #DVDRO4
need a copy of the DVDR04, help set recorder and clock.
Apr 16, 2009 | iLO DVDR04
My DVDR04 will not read any DVD+R disk.
You are using the right type Plus (+)R. So, I'd think, the unit is deffective. When I bought mine I had to take back to Walmart, and get it a different one because it was stopping me from recording my own recorded VCR tapes.
Mar 11, 2009 | iLO DVDR04
I have dvdro4 try n 2 putvhs on dvd
1. Frist put (Video & Audio) out put from your VHS.
2. Put them in DVD's (Video & Audio) Input.
3. Select AV1 in your DVD Player.
4. Done ..
Jan 13, 2009 | iLO DVDR04
User Manuel
This is the website to download manuals for the ilo DVD Recorders. Took me forever and alot of different searches, but here it is:
http://www.ilohelp.com
Mar 24, 2008 | iLO DVDR04
Ilo dvdr04 freezing picture
have you tried using a laser disc cleaner after alot of use the laser eye can become dusty and make it hard to read
Aug 24, 2007 | iLO DVDR04
Ilo-DVDR04 recorder problems
The laser is either dirty or is starting to go.These lasers in this model usually only last two years.To clean but a commercial disc cleaner philips or Maxell work good in this model.Put a drop of rubbing alcohol on brushes this helps clean laser.I would do this every 15 hours of use .The best way to clean laser is to rub gently with a Qtip soaked in rubbing alcohol but this requires some technical knowledge for you have to open burner.If you attempt this make certain electrical plug is pulled lasers cause nasty burns.
If laser is going you can replace the burner/loader unit,this model uses a 411s or 451s Liteon burner.The 401s and 813s will also work without problem.
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
ILo DVDR04 Recorder
your dvd writer is bad you will have to replace it believe me i now what im talking about i have went through 4 ilo's did the same thing plus 100's of differnt name brand dvd's
Feb 15, 2007 | iLO DVDR04
iLO DVDR04 Logo
18 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
