Question about Samsung SL-M4020ND/XAA Workgroup Monochrome Laser Printer
M4020 I need download software to reset count chip
Page count
The E232 cartridge uses a chip to set the page count on the printer. To reset this you need to replace the chip on the cartridge. Your friendly cartridge remanufacturer has access to the chip. They can source one for you.
Oct 02, 2014 | Lexmark E232 Laser Printer
My epson rx650 ink pad replacement.
Epson have there reset's pretty locked up, Agents have to register to gain axcess rights to software program tool that resets purge counter (waste count rset) , there are 7 pads in these printers just felt blocks that suck up ink and the electronic counter. all colours are mixed in felt so no draining guess you could wash them out but it is the counter that will stop you, wont go till reset. I have seen some after market ink chip resets but dont know if they work.
Epson about 6 months ago sealed up their tec support download system, now we have to identify agent and rep who is downloading the "eagle" software that is the Epson adj software that allows adjustment and reset of waste ink counter.
reseter link and another http://www.printercartridges.com.au/
Dec 06, 2007 | Epson Stylus RX650 All-In-One Printer
Samsung CLP-315w blocked after page count reset
Dear
either you buy the toner chips and image unit chips or reprogram the 24c04 on MPBA to factory value.
Thanks.
Jul 20, 2014 | Samsung Office Equipment & Supplies
I have just replaced my toner on my HP M2727 nf printer, how do I reset the page count only?
There is no resettable page count on this printer. If you are referring to the counter for the toner level, that is reset by a chip on the cartridge. That chip only works once and if you are using a refilled cartrige that chip should have been replaced. If you refilled it yourself you will need to check on Ebay to find a replacement chip. If you bought a refilled from someone else, take it back and get them to change it. If you bought an OEM HP cartridge and it does not reset the count then call HP as the guarantee their cartridges.
Jun 27, 2011 | HP Laserjet M2727nf Multifunction Printer
After reach 2.5 lakscopy the copy counter stop and further counting is irregular in CANON LBP 3300 laser printer.So I have to reset the copy count or change the printer to factory reset. Is it possibe?
Hi..
When the reset to factory setting is done, all the settings and storage tanks and drums will be cleaned, It's mean everything will be back to factory settings.
you can also try it,
But before you try what you said look at the troubleshooting map I gave
Hopefully this can help u more clearly identify your problem..
regards
Mar 03, 2011 | Office Equipment & Supplies
Hi i am using samsung ml1640 printer after refiling it gives toner exausted messafe what i do to solve the problem
When the number of pages reach the limit specified in the chip it starts to give the message that tonor is exhausted no matter if it has tonor in it or refilled. Replace the chip or tonor and it would work fine.
If its the starter cartridge try following: -
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an introductory one.
Also check out
http://www.savetoners.com/toner-products-a-services/77-free-information-how-to-refill-samsung-ml-1640-1641-1645-2240-2241.html
http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
Nov 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
Toner exhausted
open the back cover and locate the chip numbered 93c66,its above the USB port on the mainboard.short the top-left and bottom left pins and turn the printer on for 5-10 secs...that resets the page count to 0... also either remove the chip on the toner or cover it with a cellotape
Sep 01, 2009 | Samsung SCX-4300 Monochrome Laser...
ML-1640 Series + Toner exhausted.+ how to reset the printer.
Jun 09, 2009 | Samsung ML-1640 Monochrome Laser Printer
ML1640 not working after toner refilling
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung SL-M4020ND/XAA Workgroup Monochrome Laser Printer Logo
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
