Question about Proscan 32LB30QD 32 in. LCD TV
Trouble loading a dvd in proscan PLEDV1520A-C
The dvd will not automatically load into the dvd slot and I don't want to force it
Cant get the dvd to work cant put a disk in it a proscan tv dvd combo
Disc loading mechanism fault. Contact any service technician to replace it. This is not a user repairable fault.
Jul 13, 2015 | Proscan 37 in. Diagonal Class LCD...
My proscan tv dvd player wont load
If it does not open or close, most probably the driving belt has become loose or got cut.
Jul 31, 2012 | Televison & Video
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
Hi there i am unable to insert any cd/disk in the cd slot of my dell precision m6400, can u assist me?
If this isn't loading cd or dvds then your problem is the drive itself. You need to replace it. You can order parts on line or from dell. Or you can use a external usb drive. All are about the same price.
If it loads dvd but not cd then this is a new one. Usually it has problems with dvds first then cd later on. That means the heads are out of alignment and don't have the fine control for dvds while it can still do the coarse cd .
Sep 02, 2011 | Dell Precision M6400 Slot Loading 8x SATA...
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I wanna replace the DVDreader/writer in my Acer Z5600 for a Bluray unit reader/writer can I do this myself because Acerservice in Holland don't wanna do this for me...
Looking at the image of the machine; the DVD drive is a vertically loaded slot.
replacing the DVD reader/writer with a Blue Ray one... not entirely sure if it's possible without advice from the manufacturer (contact them to be 100% sure).
because of the physical dimentions of the screen; the DVD drive will be a laptop dvd drive not a normal desktop one.... so you could hunt online for a slot loaded Blue ray drive for a laptop... but again no guarantee without manufacturers confirmation.
most machines past 2005 have SATA connections inside for the optical drives; but also confirm this before spending money.
May 17, 2011 | Acer Aspire Z5600 PC Desktop
My advent dvd player in my Yukon lets me load the dvd says loading then it automatically ejects it! How can I reset the dvd player?
my dvd player will not let me load a cd -- can "force: it in - takes it almost all the way then ejects it
Nov 01, 2010 | Audiovox VOD102 Car DVD Player
Loaded dvd and now it won't play and it won't open/close
Hi i have had a similar problem to this before. I never could get it open without force, but if it is only the disc you are after then i would recommend forcefully removing the disc with a knife opening the dvd slot or by unplugging everything and unscrewing the dvd player altogether there might be something lodged in the dvd player preventing it from reading or opening. Be sure to press the power button when you unplug as it may contain electricity still.
Jul 18, 2010 | Daewoo DV6T844B DVD Player/VCR
Proscan lcd accepts disc but then gives the messages loading and than no disc
This TV/DVD has a strange design, the label on the DVD should be facing away from you. The Mirror side of the DVD should be facing you.
Mar 19, 2009 | Proscan 32LB30QD 32 in. LCD TV
26 inch Proscan with no manual
You can find the the manual in pdf form on the PROSCAN website. look under support for manuals and find the one you need and down load it for your use. The website is . www.oncorpus.com You can also call the PROSCAN customer support at this telephone number.1-888-977-6722. I hope this has helped you with your problem.
Mar 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32LB30QD 32 in. LCD TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
