Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
E32 on Canon Powershot ELPH 11515 - Canon PowerShot SD500 / IXUS 700 Digital Camera
SOURCE:
jamo297
  • 19 Answers
SOURCE: Canon Powershot SD870 IS Digital Elph will not
This solution was originally posted by rulds2008.
"The battery regulator inside needs to be replaced around $15 from radioshack or you can take it to a camera shop for around $35 bucks. If its still under warrenty Take it in and have it repaired free."
Posted on Jul 18, 2009
t00nz
  • 4738 Answers
SOURCE: Can you use an SDHC card in the canon powershot
Although it looks exactly the same as a standard SD card, the format the SDHC card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 25, 2009
  • 173 Answers
SOURCE: How do I solve error
The following is an answer taken from site: http://answers.yahoo.com/question/index?qid=20101220203847AAmODI4
"You can try a hard restart:
- put fresh batteries in the camera but no memory card;
- double click the on/off button so the camera turns on, then off;
- hit the button again and, hopefully, it will start normally.
If this doesn't help, call Canon tech support. E-series error codes may indicate hardware or firmware issues that need professional repair. In the U.S. the Canon customer support phone number is: 1-800-OK-CANON."
Hope this will help. Best of luck.
Posted on Jan 08, 2011
  • 64 Answers
SOURCE: Canon Camera Error E32. Camera
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
Posted on Jan 27, 2011
  • 6 Answers
SOURCE: canon powershot sd1400 is e32 error?
The problem is related to the mechanics in the optical image stabilization. There are 2 plastic ball bearings inside the shutter/lens module that can pop out of their round holders that are held in by 2 springs. This can occur by simply dropping the camera with the lens extended. I fixed many of these particular models and would not recommend an amateur attempt the fix as the complete lens has to be disassembled. A very poor Canon lens design.
Posted on Oct 08, 2011
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
E32 error in canon A3100 is
hi i have roblem in my camara A1300 IS , restart E32 what i do?
Mar 26, 2012 | Canon PowerShot A3100 IS Digital Camera
E32 error when i turn my camera on
I can't offer a solution but you may be able to find answers on the Canon website. Look on the support pages, they also may have a forum where others have come across the same problem. Final resort, talk to Canon themselves.
Mar 07, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Have Canon Powershot SD550 but no software
Here is a clickable and direct link to the Canon web site with the software you need for your Canon Powershot SD550 Digital Elph.
Hope this helps you!
- CBR2009
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=12466#DownloadDetailAct
Aug 18, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
