Question about Epson TM-T88III Thermal Printer
Epson tm-t88iii paralel to usb - Epson TM-T88III Thermal Printer
SOURCE: can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Posted on Sep 02, 2008
SOURCE: epson t88iii will not print
I would like to say sorry to you I got my serial port mixed up with the parallel port. I have resolved the problem, it was a DIP switch change which needed to be set. If anybody can not get their computer to communicate with the printer then I would suggest they download the Epson Technical reference guide and read it thoroughly, but only use the guides for your method of connection which is dependent on your model of printer. I found that for a baud rate of 38400 DIP switch SW 1 numbers 7 & 8 should be switched to ON .I hope this helps some else.
Posted on Dec 14, 2008
  • 25 Answers
SOURCE: Epson TM-T88III need driver cant find anywhere
The driver install packages are found here:
http://www.internationalpointofsale.com/epsondrivers.htm
And the install instructions can be found here:
http://www.internationalpointofsale.com/installingepsondrivers.html
Posted on Aug 10, 2009
  • 12 Answers
SOURCE: need driver w98 for Epson TM-T88III Thermal
The printer driver is available at pos.epson.com. You have to take a minute to set up a free account to log in, but after you do, the driver is readily available. Just click on Tech Resources on the left side, and select the correct printer.
Posted on Aug 25, 2009
  • 1570 Answers
SOURCE: In installing an old Epson T88III receipt printer
Hi
Ignore the message to install the Epson TM-2.01 and proceed to install the correct driver for your Epson T88III.
Just set up or add the correct printer driver and make you choose USB port connection not parallel port. Then try to print the test paper and if prints, then you are properly configure your printer.
If not, you have to configure the correct driver and the correct PORT connection to your printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Apr 15, 2011
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
Need drivers for epson tm-t88111 printer
Epson TM-T88iii Receipt Printer - This product has been discontinued. It is replaced by the Epson TM-T88iv.
Epson TM-T88iii Printer -> Drivers download
Hope it helps.
Nov 09, 2010 | Computers & Internet
I have a Epson TM-T88III as a networked receipt printer, we have a new machine that has windows 7 and I can not get a driver to install that works. Any suggestions?
Dear Clark, it seems you have a lot of money when you suggest to waste a printer 240€ value.
The solution:
Link www.epson-pos.com and register, after that, follow this path:
Thermal line printers
Choose your model
Epson Advanced Printer Driver for TM Series (the first option for Windows7)
Install it, it Works properly.
Jun 29, 2010 | Epson TM-T88III (C420863)
Do not suceed to print with usb-to-serial cable
use a null cable and is ok.
Diego.
compuzonic.com
Jan 18, 2009 | Epson TM-T88III (C420863)
Epson t88iii will not print
Dec 12, 2008 | Epson TM-T88III Thermal Printer
Can't install epson tm-t88iii serial
reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III Thermal Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
