Question about Salter Health & Beauty
Salter 9140 intsrution manual - Salter Health & Beauty
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
How do i down load instructions for salter ek1658 low fat fryer
go to manufactures website
type in the following information
manufactures name+model
select support
find download instructions or manual
few websites to try:
www.ask.com
www.info.com
www.wiki.org
www.searchall.com/manuals/salter_brecknell/ek1658
www.searchall.com/manuals/salter_ek1658
www.searchall.com/brecknell/manuals/ek1658
go to www.about.com
type in the following information.:
instruction manual salter ek1658
or
salter brecknell ek1658 low fat fryer
good luck rod
Mar 03, 2015 | Salter Health & Beauty
Salter
I have been able to locate a manual for Salter Mibody scales. Not sure if this is what you are after.
http://www.mibody.co.uk/EN/9119/downloads/Instructions.pdf
Aug 08, 2014 | Health & Beauty
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
Need instructions for cleaning Salter Aire Plus Compressor 8350
Click here for the instruction manual. The cleaning instructions are on pages six,seven, and eight. Hope this helps! :]
May 29, 2011 | Salter Aire Plus Compressor
New instructions for Salter digital timer model 331 please
I need instruction manual for Salter Timer 392WHXR 301.
Thank you. Please send manual to tisie@tiscali.nl
Dec 20, 2010 | Kitchen Appliances - Others
Health & Beauty Logo
44 people viewed this question
Top Salter Health & Beauty Experts
vince
Andrew Taylor
Andrew Taylor
richie46
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
