Question about iPhone Apps
How can I get BBC ONE on BT Vision when it does not appear on the list when I click on to TV Guide and scrolldown ?
yalmer
  • 552 Answers
SOURCE: codes for tuning bt vision box to sanyo tv
 There are only 2 codes for Technosonic. 0037 and 0556. I hope these help.
Sympton Problem Solution
Rolling Screen?
Black & White. PAL Video is selected in error. Click on the TV SYS button located on the DVD remote near the Power button.
Light to Dark Picture. Connection to VCR or TV/VCR combo. Unplug the DVD player from your VCR and connect the DVD player direct to your TV (bypass the VCR). If TV does not have audio/video plugs, or if you have a TV/VCR combo, you will need to purchase and install an RF modulator (available at most electronic retailers).
The light to dark picture? Condition is caused by the disc manufacturer's license encoding at the time of manufacture. It is not cause by the DVD102 player.
No Video. TV needs to be switched to the correct input mode. Your TV must be switched to the correct video input selection. You can only switch the TV to accept an outside video source by using the original factory remote. Locate the button on the factory remote that switches the TV input. The most common descriptions on remotes are: GAME, TV/VIDEO, A/V, VIDEO, INPUT or SOURCE.
Universal Remote Code. The code has not been published. The Universal Remote manufactures create the codes.
Region Error. Software issue. Return the DVD player.
Unit Displays No Disc Even After a DVD has Been Loaded. Defective unit. Return the DVD player.
Unit Displays Loading Even After Giving Adequate Loading Time. Defective unit. Return the DVD player.
Here is what I was able to find.
If not let me know and I will try finding more info
Posted on Feb 14, 2008
  • 1694 Answers
SOURCE: bt vision remote
www.remotecodelist.com .....................................T.
Posted on Mar 22, 2008
shawty-lozzy
  • 151 Answers
SOURCE: how do you connect bt vision to a sony bravia kdl
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Posted on Jul 23, 2009
SOURCE: TV guide now only shows BBC channels
Have you tried a re-tune of the dvd
Posted on Aug 04, 2009
SOURCE: I have a Bush 2878 TV and have just got BT vision
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Posted on Oct 28, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
Need a code for my bt vision remote control? I have a panasonic tv.
0075 0099 0101 0104. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 20, 2014 | Televison & Video
Bt com help btvision
contact bt vision its a free service you have to push some of the buttons in a particular sequence only they can tell you
Jan 14, 2014 | Computers & Internet
Bt vision box
you must call to the company supplier for to see if there are a problem with the upgrade, in the signal or model, and adjust.
If the problem is o.k so can reset the r.control in menu to factory default. Otherwise you must the TV with some repair shop TV for fix it. However you must setup in the MENU to go factory default. Retest any cable dirty or corrosion, clean it with solvent cleaner contacts, buy it from any stores from supplier electronic devices, like computer, etc
God bless you
Jul 12, 2013 | Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
Bt vision remote
Mar 20, 2008 | Televison & Video
Bt vision codes for remote controls
HI Angie,
If the codes are not listed, you may want to try the search fuction. It take a bit of time, but if the code is factory installed ( some aren't ) in your remote contol, you can normally find the right code by searching manually. Good Luck and have a great week.
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | Televison & Video
iPhone Apps Logo
62 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
