Question about RCA 25425RE1 Phone
How do you replace the answering machine greeting?
Trying to put an updated greeting on the answering machine, the machine records the new message but I can get it to be the greeting on the answering machine
4 Suggested Answers
SOURCE: How to I record a message for answering machine
Press "MENU"
Scroll to "Answering Machine", Press "Set/Save"
Scroll to "Record Greeting", Press "Set/Save"
Following Instructions that appear on LCD screen to record message.
Posted on May 27, 2009
freetek
  • 5568 Answers
SOURCE: how do i reset the answering maching?
This is not a 'generic' problem; it needs a model number in the message and if you have that, download the manual for it. The procedure is not the same for all RCA devices.
Posted on Oct 17, 2009
SOURCE: Answering and memo systems will not record or
I had the exact same problem. But mine was due to a slight power surge even though I had it plugged into a backup battery with a surge protector. I called RCA and they said this model has a history of answering system malfunctions with power surges. It has a two year warranty. Gave the girl my info from my receipt (although it sounded like I really did not need the actual receipt). She gave me an RMA # so they are shipping me a new unit. I have to pay for return of the bad unit though. Try calling them @ 1.800.511.3180 and explaining your issue. Good luck!
Posted on Dec 04, 2009
How do I put my own message in my answer machine .?
you have not bothered to give the make and model of your phone so this answer is relevant to uniden dect 1635 but will be a guide to your unit as well as most use the same format
recording a personal greeting (2 to 30 seconds long)
1--open the menu with the phone in stand-by
select answering setup, then record greeting
2--press menu/select to start recording Wait until the system says --"record greeting" before speaking
3--press menu/select to stop recording. The system plays back your new greeting
4--- to keep the message press end
to re-record it press menu/select
in your manual look for the section " using answering system" or "personal the greeting"
Jan 07, 2016 | Lands Phones
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Want to put a message on the answering machine - loss when electricity went out.
Simply hold down to greeting button for around 5 seconds and it will tell you to record you new greeting. To stop greeting recoding after you finished speaking then just push play. Listen to your new recorded message.
Aug 23, 2010 | Uniden Cordless Phone exai398i
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
or use a prerecorded greeting
message.
message
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
How do you remove a recorded answering machine message
Settings:
In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up;
* Active in profiles - defines in which profiles the application will pick-up the phone and record messages;
* Storage - allows selecting on which disk the records will be saved;
* Pick up after - sets the time after which the call will be answered;
* Record time - maximum amount of time the message is being recorded;
* Format - message file format (amr,wav);
* Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application;
* Play volume - play volume for the greeting;
* Records lifetime - automatically removes old messages;
In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller;
* Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
Jun 23, 2009 | Nokia Cell Phones
Answering Machine Message
enter answ.mach setup menu
then record greeting submenu
press start soft key
youll hear start recording mess
you have 30 sec v countdown to do message then it automatically uploads
Mar 12, 2008 | Uniden TRU8885 Digital Answering Machine
Recording new greeting
#1 Try changing the 9Volt Battery
#2 Hold down the greeting button,wait a couple of seconds and record your message
Jul 24, 2007 | Conair TAD2018CG Digital Answering Machine
User manual of GE 29878GE1 Digital Answering Machine
From the Manual: RECORDING THE GREETING Before using your new answerer, you should record a greeting (the announcement callers hear when your answering system answers a call). If you don't record a greeting, callers hear a default greeting which says, "Record message after tone." When recording the greeting you should be about 6 inches from the unit. Eliminate as much background noise as possible. 1. Prepare your greeting. Sample Greeting: Hi, this is (use your name here). I can?t answer the phone right now, so please leave your name, number, and a brief message after the tone, and I?ll get back to you. Thanks. 2.Hold down the GREETING button. After the tone, you have 30 seconds to record your greeting. 3.Release the GREETING button when you finish. The greeting will playback automatically. NOTE: Your recording time should not be less than 2 seconds. Otherwise the unit will return to the default greeting.
Jun 05, 2007 | GE 29878GE1 Digital Answering Machine
RCA 25425RE1 Phone Logo
23 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
