Question about Torin Big Red Torin 2-Stage Transmission Jack - 1/2-Ton, Model TR4055
Why Is The Screw UuderneathSaddle Bent. Suppose To Be Bent. An What Is Purpose Of This Part Of Jack
What would cause the blade to not cut strait?
mower blades are guided by just two bearings inside the spool housing ,if they are not true and running perfect it will cause the spinning blade to wobble , this will produce a High/Low effect in grass cut height (in fact golf courses do this on purpose for visual effect in Bounding markers) also if blade is bent from striking a solid object they will effect there cut as well , and finally if blade is dull it will merely lay grass blades down and next day (sun)it will appear to have grown in short time l, blades should be kept sharp and true with no bends that arnt suppose to be there
Feb 17, 2016 | Garden
Door works but lights will not go on and bulbs are good
The contact tab in the socket is bent downwards. Disconnect the opener and pull that tab upward enough with your finger (it won't zap u unless you forgotten to unplug it!) So that when you screw the bulb in it will make contact with the bottom of your bulb. Or you may have a loose connection inside the motor housing unit. If neither of the two work it's your main logic board. Secondly if you get it to work I suggest garage opener bulbs. Their ideal for that specific purpose but any low watt bulb should be okay.
Jan 29, 2016 | Building Materials
Juki ddl 8300n
The part that holds the bobbin case down must have enough room for thread to move across the top of the bobbin case without getting jammed. Turn the hand wheel while you monitor the movement of the thread. If it gets jammed you will have to adjust the holder by loosening the bottom screw and move just a small amount. Also check your bobbin to make sure it is the right size. If it is too high it will jam the thread.
Mar 24, 2017 | Sewing Machines
How do i get a lower control arm to pry down if it does not budge?
I use a jack for this purpose The on that has a screw in the middle and pulls the pivots together to go up. use care and do not go any further than necessary to clear the hole
Mar 26, 2013 | 2002 Ford Taurus
How do I replace the oil pump on my 2004 aveo 1.6
first drain oil from pan to prevent making mess ion floor.
Then remove all oil pan screws and pry pan off making sure it does not get bent.
If bent lightly tap with hammer on flat surface like workbench.
Some models are designed so that getting at all the screws is impossible. In that case you might have to remove engine mounts at the engine block and lift with a floor jack.
safest jack is a transmission jack.
the engine should be tied off with some heavy wire to prevent falling on you with a 4x4 or wood fence post.
Remove the metal baffle, should be only one screw.
Baffle is metal rectangular piece and in the middle.
The oil pump uses 2 screws and might have to tap lightly with hammer to remove.
Clean out the oil passage where the pump came off with a rag and thin screwdriver.
Clean baffle with some solvent and make sure it reseals properly when reassembling.
Remember to clean all parts to prevent leakage when reassembling.
Feb 07, 2013 | 2005 Chevrolet Aveo
PURPOSE OF INPUT JACK
The purpose of the input jack is so you can hook things into the TV. ie a dvd player, cable box or sat box. video games
Jun 19, 2012 | Televison & Video
I got a spring problem, How do I get it back into the connector so it stays right there by the jack?
This is what I did after I couldn't find an answer online. Took the fat end, and kind of like a key chain ring, bent the last tiny bit where the spring ends. Then took this bent bit and then like a screw lead that into the jack end. From there just go in a circle and push the next bit of the spring into the jack end in a circle until all of the thicker spring part is back up and under the lip of the jack.
Feb 06, 2011 | Audio Technica ATH-M50 Professional...
Can a bent wheel rim cause a problem for emergency brake cable
Does it have what's called trailing arms on the rear suspension ---inspect the main BIG bushings
that connect it --common problem on alot of vehicle
some are DIY some are not depending on basic hand tools skills and proper support
jack stands ---plural on purpose --safe dry location
some are easy bolt in and replace some are press in and out --- a machine shop or "Friend" may Macguyver it for you and poof fixed ---ahhh it's free advice take what you can---
Apr 07, 2009 | 2000 Plymouth Breeze
Needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Jan 30, 2009 | Brother XL-5130 Mechanical Sewing Machine
Torin Big Red Torin 2-Stage Transmission Jack - 1/2-Ton, Model TR4055 Logo
397 people viewed this question
Top Torin Big Red Hoisting Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Are you a Torin Big Red Hoisting Expert? Answer questions, earn points and help others
