Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Increase water level in a bosh washer - Bosch Nexxt Premium WFMC6400UC Front Load Washer
Washer not filling to rinse
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jul 09, 2011 | Fisher Paykel EcoSmart GWL15
Our washer is not filling with enough water. We set it for a large load and the water level is that of a medium or maybe even less.
Hello there and thank you for choosing fixya
May 24, 2011 | Kenmore Washing Machines
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
Apr 17, 2011 | Washing Machines
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
It does fill to capacity on the rinse cycle only on large or super levels.
Jan 06, 2011 | GE WBSR3140DW Top Load Washer
Bosh wasmachine doesn't was clothes
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
Mar 23, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
Washer is running water but its not filling up
Jan 02, 2010 | Fisher Paykel EcoSmart GWL15
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
Water level
NO you cannot increase the water it is designed to use a low amount of water which is why it is considered an energy effecient washer
Oct 13, 2007 | Kenmore 44042 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
