Question about Nintendo DSi Matte Blue Console
How to download songs from MAc onto DSi?Do I need the SD card? If so, how does the SD card interface with the computer? I can probably figure out how to convert iTune songs to whatever format is supported by the card- but how to actually get the songs onto the card.
  • 122 Answers
You must have a card reader for your computer in order to add songs to an SD card. You will need an SD card in order to get Music onto your DSi. You can often purchase a USB card reader specifically for an SD card for cheap. Check your local electronics store. All you will need to do then is copy the .MP3 files over to the SD card. It works exactly like a Floppy Disc or a Flash Drive. The DSi should already have the software it needs to run .MP3 files.
Posted on Jun 24, 2009
  • Matt Hughes
    Matt Hughes Jun 24, 2009
  • 51 Answers
Fisrt you need to buy a R4i card. From their you will jsut be able to make a folder and put your music files into it. ONce the card is put into the ds moonshell which is the homebrew media application will detect the music files and enable you to play them. Ihope this helps. If it does please rate me.
Playing songs on my dsi
Hello subodhkelana
1. Insert your SD card into your PC/Mac/external card reader/writer.
2. Open Windows Explorer (PC)/Finder (Mac), and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer/Finder, and navigate to where your music is stored.
4. Highlight the desired file(s) and/or folder(s), copy them, and then paste them into the first instance of Windows Explorer/Finder to create copies on your card.
Hope this helps. Please don't hesitate too contact me should you require any further assistance.
ajblaj
May 08, 2010 | Nintendo DSi White Console
How do you download music on a dsi
Hello sherribaxley
As far as I know, there is no direct way to download music onto your DSi. In order to listen to songs on your DSi, you will first need to copy the songs you want to listen to onto a compatible SD or SDHC card. Not all songs are compatible with the DSi. Some songs may be copy protected and will not work. The DSi is compatible with AAC audio files with a filename extension of .m4a, .mp4, or .3gp.
WHAT YOU'LL NEED
- A compatible SD or SDHC Card. The DSi is compatible with SD cards up to 2 GB and SDHC cards up to 32 GB.
- Compatible music files stored on a PC or MAC.
- An SD Card slot in the PC or MAC, or an external reader/writer
WHAT TO DO
1. Insert the card into the slot.
2. Open Windows Explorer (for PC) or Finder (for Mac) and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer or Finder and navigate to where the music is stored.
4. Highlight the desired file(s) and/or folders, copy them, and then paste them into the first instance of Windows Explorer or Finder to create copies on the card.
If you need to convert the format of your music files, there are many freeware applications available to download on the web. I personally would suggest using iTunes, as it has a built in AAC converter.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
May 03, 2010 | Nintendo DSi Matte Blue Console
Need help puting music on ACC file
To convert music to AAC files you have to download itunes, if you dont allready have it, when you have done that play the songs you want to convert one by one in itunes, has you play them right click on the song, then right click create AAC version, when the track as been converted you will hear a bell sound, then right click again and click show in windows explorer, the songs you convert will go into a windows folder, the best way to do it is when the song goes into the folder drop and drag them onto your sd card, then as the songs go into the folder do the same, you can put them in a music file on your sd card to make it easy to open when in your dsi, when you have all the songs on your sd card, pop it into your dsi, then open the music folder and play your songs, hope this helps you cheers Roger M.
Jan 19, 2010 | Nintendo DSi Black Console
I have dsi and a ttdsi card and ther sd card.
Did it work before? Is this a new card? If it's new, and you've never used it before, you probably have to download the 'software' to make it work.
I have the R4i card, and that is the way it works. Go to whatever the manufacturers website is (usually listed on the packaging, or the card itself) and download the software to make the card work. They can't pre-install the software, otherwise it would be illegal to the sell the cards.
It's also possible that your DSi has version 1.4 firmware. If this is the case, there are only a few cards that are compatible with this firmware, and the TTDSi you have may not be. If your TTDSi card doesn't specifically indicate that it supports Firmware 1.4, and that is what you have, most likely you will never get it to work, even if you install the menu software onto the SD card.
Good luck...
Nov 21, 2009 | Nintendo DSi White Console
How do you play music saved on an SD Card?
1) frm da music on iTunes, right-click,then click on CONVERT 2 aac.another track(identical) should come out.
2)after completing step 1, go 2 my computer nd open the SD card up,create new folder or use da one u used 4 ur other music.
3)after step 1&2 copy nd paste ur song(s) to the folder u had open.hope dis helped
P.S. make sure u converted ur songs 2 AAC(aac) or else it wont work.
Nov 08, 2009 | Nintendo DSi Black Console
How do i put music of my pc onto sd card for dsi
You have to download itunes if you have not allready go it, you have to put the music you want on your dsi into a playlist on itunes, if you play it on itunes just stop the tracks and right click and pick create aac version, they have to be aac files to play on your dsi, once you have converted the music you want, right click on the tracks you want and pick show in windows explorer, then when you have them in that file, drop and drag the tracks to your sdcard,after you put the card into the pc, you can not put them on your games card because you have to put the card in the side of your dsi to be able to play them, once you have done that, turn on your dsi and open the file for the music and play the songs, if you try and put mp3 files onto the card the dsi will not play them, only if you put them on you games card, and into a system files, then the dsi will play them.
Oct 05, 2009 | Nintendo DSi Black Console
I dont know how to put music in the sd card
To add music to your DSi, first you need a spare sd card, and a pc or laptop that can sync with the card. Remember that the DSi only plays AAC type songs, so convert the songs you want to copy-paste on the card. This can be done easily on Itunes on which I use by right-clicking on the song and it will show you there ' convernt to AAC'. After saving the songs , take out the card from the pc or laptop and you can now insert the card in your DSi and play music and enjoy.
May 30, 2009 | Nintendo DSi Matte Blue Console
How do I put the downloaded games in my Nintendo DSi's sd card?
ummmm u need to have an sd card this is a AAC
then put it in your dsi slot on the right then now read the steps
1.go to settings
2.go on data managemen
3.select sd card
4.click on your game
May 11, 2009 | Nintendo DS Lite Console
How to download songs from computer?
The new Nintendo DSi console can now play music, however it can only play AAC file type music, so if you have MP3 type, converting it is as easy as pie in iTunes. Also, once you have converted the songs, you need an SD card to store the songs in, and once done, you can put it in the DSi SD card slot and then play your music.
Hope this helps.
May 04, 2009 | Nintendo DSi Black Console
Nintendo DSi Matte Blue Console Logo
988 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
