Question about Fender Audio Passport 500 Pro Speaker PA System
What causes the passport 500 pro to cut out
Sound goes on and off and sometimes wont come back on
2 Suggested Answers
  • 5603 Answers
SOURCE: One of my Fender Passport
You have probably blown the speaker... swap left and right to verify it is the speaker... These speakers are NOT too well suited for bass... They typically have low impedance speakers in series. You run a risk of popping the amp running with a blown speaker. You MAY have to replace all the speakers in the defective cabinet. ALL the speakers must be identical. The Passport 250 uses four 2 ohm speakers in series... not sure about the 500. It may have two 8 ohm in parallel. Do not use the speaker until it is fixed... the amps are hard to repair if a defective speaker cooks them.
Posted on Sep 08, 2011
Fender Passport pro 500 - speaker static temporary, then goes away. Usually occurs shortly after turning system on.
If this system is still under warranty get it to a warranty service center. This is an early stage symptom of failure with the Power Amp IC. Fender has a good warranty policy on this stuff - 1 to 3 years
If not under warranty you may want to wait until it the problem is more persistent - easier for a tech to fix - unless it IS every time right now. A good tech can identify the issue quickly once "on the bench". My 'gut' feeling is the Power Amp IC when the system is first energizing to full stable power.
Oct 26, 2013 | Fender Passport Deluxe 500watt Sound...
Fender Passport Pro 500
Fender Passports are notorious for being badly built with poor reliabilty. Trade it in for a fiver and buy something of better quality.
Nov 01, 2017 | Music
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
One of my Fender Passport 500 speakers has started to crackle sometimes, particularly when the song has a lot of base. What could be causing this? Would a regulator help?
Sep 08, 2011 | Fender Passport Deluxe 500watt Sound...
Fender passport 150 pro- Bought to uses for "Bike Nights" Plaing cd palyer in small retail parking lots. Volume is too low, when ever I try to put input level beyond halfway,,, I get...
You are in danger of popping the amp. The Fender passport 150 would be capable of covering about only a 20 foot by 20 foot area. If your area is bigger than that, you need more power and certainly bigger speakers. I would NOT recommend the larger Passport systems as the speakers are too directive for what sounds like your use... also there are reliability issues.
Aug 05, 2011 | Fender Passport Deluxe 500watt Sound...
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Fender Passport 500 System Speaker showing 'red'.
Unless you abused the cable badly, this is UNLIKELY. More probable is failure of the amplifier.
'The Speakon connectors are usually pretty reliable,
Apr 09, 2010 | Fender Passport Deluxe 500watt Sound...
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
Fender passport goes in to protect
I had a problem like this that was caused by a short between the two windings of the toroid in the power supply.
The solder blob is probably supposed to be there as there are numerous common ground points.
This unit is miserable to work on....
Sep 08, 2009 | Fender Passport Deluxe 500watt Sound...
Fender Audio Passport 500 Pro Speaker PA System Logo
29 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
