Question about Kenmore Kitchen Ranges
Managemylife I HAVE AN ELECTRIC RANGE I BOUGHT 2YRS. AGO, IN THE THE LAST FEW DAYS I NOTICE THAT THE OVEN DOESN'T GET HOT WHEN I PRESS THE BAKING KEY.NOW IT DOES GET HOT WHEN I PRESS THE BROIL KEY. I'M NOT SURE IF THE INTERNAL SWITCH IS WORN DUE TO THE USAGE OF THAT KEY.
the dr
  • 447 Answers
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Posted on Nov 16, 2007
SOURCE: KitchenAid gas range superba not reaching/registering right temp.
kitchenaid superba electric double oven "takes too long to heat up"
Posted on Dec 06, 2009
  • 30 Answers
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Posted on Jul 02, 2010
SOURCE: KGST307 Gas Kitchen Range: gas range will not heat up when using Bake setting...
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
Managemylife
The top heating element comes on when you call for broil and your bottom comes on when you are set to bake. If the bottom one is not coming on when you set to bake then it is most likely bad and needs to be replaced.
May 06, 2014 | Kenmore Kitchen Ranges
Top oven of dual oven unit not reaching tempature
There are a a few things you'll want to check.
1) place the machine on bake to verify the bake element is coming on then do the same for the broil element. In normal operation both of these elements are supposed to come on helping the machine reach temperature quickly.
2) If both elements are working, let the machine cool down and then locate the oven sensor. This is going to be located at at #453 I believe on the diagram I list below:
http://www.partselect.com/ModelFrames.aspx?ModelID=1589442&ModelNum=JB850SP2SS&mfgModelNum=&ManufactureID=2&Selected=00133082i03&Position=7&mfg=GE&Type=&Mark=7
using an ohm meter this can be check and should measure out at 1099 ohms. If there is a slight difference, say something like 1087 ohms, it will cause a major difference in performance in the machine working right.
Jun 19, 2012 | GE JB850SPSS Electric Ranges
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Mer5755qab oven takes an hour to heat to 200
Either your bake element is bad or there is a bad connection going to the element. This is a very high current connection so bad connections are always a possiblity. Also check and make sure your broil element is working as some ovens use it for pre-heat. Do both elements seem about the same temp? You can turn the oven on and carefully hold your hand a few inches from the element to see if they are getting equally hot. If your connections are good to the elements then one of the "calrod" elements is probably bad. You can also check the resistance of each element. Not sure of exact reading but a higher resistance means less current going to the element. Just compare reading on each one and go from there. Good luck!
Mar 13, 2009 | Maytag MER5775Q Electric Kitchen Range
Oven does not work
I assume the oven has worked at one point? Does the broil still work?
This is my experience with my White-Westinghouse gas stove:
The igniter bar is toast. There is 1 igniter bar each for the bake and broil (1 on top, 1 below). This is instead of a pilot light. Its an element that heats up to be hot enough to ignite the gas. If it doesn't get hot enough, the gas does not turn on and therefore not heat.
I went to my store and asked about this. "90+% of the time, that's the problem" So I bought a replacement and installed it myself. Problem fixed. Just had to undo a few screws to get at the bar, then connect the new one's wiring under the stove using marettes & some electrical tape, but the rest back together and that was it. I think the part cost me about $60-80 here in Winnipeg a few years ago. But it would've been at least that just for the guy to show up to look at the stove, never mind fixing it.
Dec 04, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
