Question about Torin Big Red Torin 2-Stage Transmission Jack - 1/2-Ton, Model TR4055
The Saddle Has A Knob ON Screw That Goes Under Saddle Whats Its Purpose And Is The Screw Suppose To Be Bent On One End
How to change a choke cable on a morris minor
older choke cables have the knob removable.. look underneath the knob for a very small screw. This screw goes into the brass end of the cable and when the knob is removed the nut on the front of he dash can be undone and the cable assembly comes out from the back.
Dec 01, 2014 | 1969 Morris Minor
Top cord handle fell off
The spring is part of the silver power cord clip that you flip around at the top of the handle to release the power cord that has been stored in a coil sour the fixed position plastic hook at the bottom of the handle and this one at the top. There is a long silver screw that goes through a washer then through this clip. The clip is in two parts, the hook or clip that rotates and a saddle that is stationary against the handle. The spring then goes on the screw under the saddle and finally is skewed into the handle.
Mar 16, 2014 | Riccar 8955 Upright Vacuum
Not playing in stereo
You have blowin a IC in it, Power amps are not suppose to be use for the purpose you were useing it for.You are dam lucky they didn,t go up in smoke.
Oct 16, 2012 | Rotel Audio Players & Recorders
How to take battery out
The battery on this bike is under the saddle. You will need to remove the rear seat, which is held in with a 6mm allen head screw. Once you remove the rear seat (if so equipped) you will see an odd looking bolt holding down the saddle. It has a cylindrical head over and the actual bolt head under that. Remove that bolt. Remove the saddle by lifiting up and back. You will see the battery right there
Nov 23, 2010 | 2003 Suzuki VS 800 Intruder
How do i get to the battery? i know its in front of the rear tire at the bottom of the bike, i need to jump it.
The battery on this bike is actually under the saddle. You will need to remove the rear seat, which is held in with a 6mm allen head screw. Once you remove the rear seat (if so equipped) you will see an odd looking bolt holding down the saddle. It has a cylindrical head over and the actual bolt head under that. Remove the saddle by lifiting up and back. You will see the battery right there.
Aug 04, 2010 | 2003 Suzuki VL 800 Volusia
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
Fender Jazz Bass E string saddle vibrates down
Hi Mike,
If the sound is like a string vibrating against something, ensure that is not strings (usually G) vibrating against the bridge.
Ensure that the two screw on the saddle are well in place.
Ensure also that the vibration is not coming from a string vibrating against the frets, in that case you can fix the problem by adjusting the action and rectifying the bow of the neck.
In either case, if the sadde and neck bow are cause of vibration, try tweaking the saddles a little, and lowering the position of the saddle a bit downward. Try also to rectify the neck. turning the apposite screw.
Mar 12, 2009 | Fender& Standard J Bass Artic
Torin Big Red Torin 2-Stage Transmission Jack - 1/2-Ton, Model TR4055 Logo
451 people viewed this question
Top Torin Big Red Hoisting Experts
JAIJITH
John Kopischke
John Kopischke
Level 1 Expert
gbob59
Are you a Torin Big Red Hoisting Expert? Answer questions, earn points and help others
