Question about Whirlpool GS563LXS Kitchen Range
After a blackout I was not able to unlock the stovetop even after following the unlock procedure
Everything else works.....just can't unlock the stovetop burners according to the manual instructions.
Why does everything blackout on my 2004 Expedition and start when I disconnect the battery and reconnect it?
Sounds like you might have a similar issue: http://www.ford-trucks.com/forums/196821-odometer-blackout-problem-fixed.html
Oct 12, 2012 | 2004 Ford Expedition
Am using verizon 9530 unlocked. phone is working, the backlight is active on buttons...!! the screen is not active.. i could answer / receive calls.. can hear the notifications of receiving emails /...
When you get your blackberry screen blackout? After your blackberry 9530 unlocked or a few days after you unlocked your phone? Did you get my point? If you get that blackout screen after blackberry unlocked process try to reset your phone to default factory setting and if still not working try to reinstall your blackberry os, but if you get that blackout screen a few days after you unlock your phone looks like your screen already broken and you need to replace it in your nearest local mobile repair shop.
Jun 11, 2011 | RIM BlackBerry Storm 9530 Smartphone
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
Igniters on stovetop work intermittenly model #cgs3760adq
You didn't say how old the appliance is but:
Check the spark gaps at all of the ignitors at the burners and also be sure everything is as clean as possible. The ignitors have a service life.
If the problem persists, there could be an issue with the control board.
Dec 12, 2009 | Kitchen Ranges
Htc fuze unlock code
Even lots of way are available to unlock a mobile the best way to unlock a mobile is u can visit this site http://www.unlocking4u.com/unlock-your-phone/rs6wp2/ get the code & follow the procedures step by step u can unlock your mobile.
Jun 06, 2009 | HTC FUZE Smartphone
Stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
May 29, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
My t.v. picture goes on and off.
Follow up: The audio/video blackouts were in fact a precursor to the bulb going bad ( even though no lights on front indicated such as the manual suggests). Replaced it, blackouts went away. Picture is noticeably brighter, so the bulb was showing signs that I didn't pick up on. If you're reasonalby handy, the lamp assembly is an easy fix for approx $200-$250 .
Dec 22, 2008 | Sony KDF-E55A20 55 in. LCD Television
Open Questions:
This range has worked fine for over 3 years. We use the oven a lot, the broiler not often. Last evening after using the stove for several things, then the broiler very briefly, both of them stopped working. The "Preheat" display comes on, then you hear the loud click (which I assume is an electronic valve), then instead of hearing the burners ignite, you get another loud click, no ignition. The stovetop burners all work. -------------------------------------------------------------------------------- Following up on my own question here, I found a document online titled Whirlpool Gas Range Direct Spark Ignition System, which applies to this range. I got a multimeter, followed the directions in the document. Seemingly this procedure indicated this Spark Ignition Module, which controls both the broiler igniter and the bake (oven) igniter, was bad. Then, just to be thorough, I tested the double solenoid which is part of the electronic Gas Distribution Valve which runs gas to the bake burners and the broil burners. The broil terminal was dead. This manual says if one is dead, neither will operate. The solenoid is tested when it is disconnected from the oven. The solenoid IS connected when you test the spark ignition system. So, my tester showed two problems, and for either one, the manual says replace it. But, it's hard to believe both parts went bad at the same timel So, I hope the gas distribution valve solenoid is the whole problem. Anyway, I going to replace that first, and see what happens. Does that make sense?
Feb 28, 2017 | Whirlpool GS563LXS Kitchen Range
Whirlpool GS563LXS Kitchen Range Logo
42 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
