Question about badoo Android Apps
What happens if you choose not interested?
When you get a message you can reply or choose not interested. if you choose not interested what does the other person see.
How to block text messages
You can block text messages from a specific number or contact on your Android device with a third-party solution. Just follow these steps.
Blocking Text Messages
Option 1
Note: These steps are for the stock “Messaging” app included with Android 5. Some carriers may include a different app for messaging.
Open “Messaging“.
Press the “Menu” Menu icon icon located at the upper-right corner.
Select “Blacklist“.
Set “Blacklist” to “On“, then select the plus (+) to add a person to block.
Type the number you wsih to block. Check “Block incoming calls” and/or “Block incoming messages” as desired, then select “OK“.
If you wish to remove a number from Blacklist, select the number, then choose “Delete“.
Option 2
If your messaging app does not offer a Blacklist option, use Handcent.
Download and install Handcent SMS for your text messaging needs. It’s available in the Google Play store.
Since you’ll be using Handcent for text messaging, disable the notifications for your current text messaging app. Otherwise, you’ll get double notifications for text messages.
Open Handcent then select the “Menu” Android menu button icon at the upper left corner of the screen, then select the gear in the lower left corner of the screen.
Select “Security & privacy” > “Manage blacklist“.
Tap the plus (+) icon to add the phone number you wish to block. You can choose one from your contacts, call logs, or input the number directly.
Now all of the text messages from that person will be blocked and not visible in the Handcent app. You won’t get notifications you’ve received a message from the person either. If you ever want to unblock the person, return to the “Manage blacklist” screen, tap it, then select “Unblacklist“.
Some users have reported that the app “Private Space” works well for them.
Sending an Automatic Reply
If you want to let a person know they have been blocked, you will need to download and install SwiftReply. SwiftReply will allow you to setup an auto reply for specific Contacts.
Ensure the mobile number you wish to block is listed in your Contacts.
Open “SwiftReply” and tap the plus icon (+) to make a new auto-reply.
Type the name you would like to use for the reply and the text you would like to send to the person.
Scroll down and select “Enable User Filter” > “Contacts“.
Tap “Add” and choose the people in your Contacts list that you would like to receive the reply. Tap “Done” when your list is complete.
Tap “Save“, then tap “Off” to turn the auto-reply on.
The specified people will now receive your message automatically and Handcent will block them from your view.
Feb 04, 2016 | Cell Phones
How do I set up an out of office message in Outlook 2010?
You can create part-time or temporary 'Out of Office' automated replies in Microsoft Outlook. These can be set so that whenever you leave the office, an auto reply is sent.
This is useful if you have a high volume of e-mail messages and are expected to reply to them quickly.
You can fully customize your auto reply in Microsoft Outlook 2010.
Launch Microsoft Outlook from the Start Menu.
Click "New E-mail." Click "Plain Text."
Enter the message for your out-of-office reply in the main body of the text.
Click "File," then "Save As." Click the "Save as type" list and select "Outlook Template." Enter a name such as "out of office" and click "Save."
Click "File," then "Info." Click "Rules and Alerts," then "New Rule."
Click "Start from a blank rule," then "Check messages when they arrive," then "Next." Set "Sent Only to Me" in the conditions list and click "Next."
Select "Reply using a specific template," then choose "Specific template" on the next page as well.
Click "Select a Reply Template." Choose the template you already created and click "Open." Click "Finish," then "OK." All e-mails will now have the out-of-office reply. Disable it in "Rules" to switch it off.
Hope this helps
Oct 26, 2012 | Microsoft Outlook 2010
I initiated a message through someone's facebook. THat person replied. When I tried to reply back, though my gmail, it was automatically sent to "noreply@facebook.com". Does this mean that...
You can't reply to that message it was really sent intended not to be replied that's why it contains the word no reply cause it cant be replied.
Jul 01, 2011 | Facebook Social Network
I can't send a message---when I hit reply to a message or hit send to try to send a new one to someone, nothing happens.
Don't have a fix, but same thing started happening to me this morning. When I hit Send or Reply nothing happens. All was working fine last night? Must be a Facebook glitch??
Aug 25, 2010 | Computers & Internet
How do i reset the settings so that the default message is SMS
Changing your text message
settings
Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you
can do this using the Settings options.
Press Menu, select Messaging, then choose
Settings and Text message. You can make
changes to:
Message types - Convert your text into
Voice, Fax, Paging, X.400, Email or ERMES.
Validity period - Choose how long your
message is stored at the message centre.
Delivery report - Choose to receive confi rmation that your message was
delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details
for your message centre. Character encoding - Choose how your
characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to
send your message as SMS or MMS when you enter a text longer than 2 pages in the message field.
Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message
settings Your KC550 message settings are predefi
can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message.
You can make changes to:
Slide duration - Choose how long your
slides appear on screen. Priority - Choose the priority level of your
multimedia message. Validity period - Choose how long your
message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
FOR MORE SEE USER MANUAL
good luck
Mar 21, 2010 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
No choice of including?excluding original message in replies to email.
It is possible in Gmail account.If you have a gmail account Jus try once.U can able to do that
Mar 09, 2010 | Yahoo Mail
The font size of my incoming email is too small. How do I finx it
To customize the fonts used by default for reading and composing messages as well as replies in Outlook:
Select Tools | Options... from the menu.
Go to the Mail Format tab.
Click Fonts... under Stationery and Fonts.
Use the Font... buttons under New mail messages, Replying or forwarding messages and Composing and reading plain text messages to choose the desired font faces, sizes and styles.
In Outlook 2003, use Choose Font... for When composing a new message:, When replying and forwarding: and When composing and reading plain text:.
Click OK.
In Outlook 2003, if stationery is defined to be used by default under Use this stationery by default:, the font specified in it may override the font you have just specified. You can either choose "<None>" as the default stationery, adapt the stationery to include your favorite font, or make Outlook ignore font specified in stationery altogether.
Click OK again.
Jul 07, 2009 | Dell Dimension 3000 PC Desktop
No email can not be sent or compuse or reply
After deleting and recreating an account in Mail, you might not be able to send emails even if you can receive them. When you try to send a message, this alert may appear:
"Cannot send message using the server smtp.xxxxx.com"
This happens if the Simple Mail Transport Protocol (SMTP) server, used for outgoing messages, was incorrectly entered with the first account even if it was correctly entered for the replacement account.
Products Affected Mail
Resolution You should first verify that the network connection you're using is the correct one for the ISP that you want mail to communicate with.
  1. Open Mail.
  2. From the Mail menu, choose Preferences
  3. Click Accounts.
  4. On the Outgoing Mail Server (SMTP) pop-up menu, choose Edit Server List.
  5. Delete all entries for the SMTP server that is mentioned in the error, and click Done.
  6. Configure the current SMTP server by clicking Server Setting.
    Note: If you need to use multiple SMTP servers for multiple Mail accounts, see this document.
  7. Send a test message to your email address.
Jun 02, 2009 | Yahoo Mail
Can't reply to txt messages it freezes
The phone may require to have its operating system purged and then reloaded. There may be some corruption in the system. The only other fault that can normally cause this is an intermittent hardware failure. The only way to know for sure is to start by having the operating system and all the software re-loaded as like when the phone was new. Don't add back any other optional non original programs until you established that the phone is working properly.
A common cause of damage to the operating system, is when people load in various non approved programs and utilities. Some of these programs may have errors in their code, and thus cause fault conditions.
We use Blackberries in our facility. When the users start to load in various programs from all over we start to have some very interesting fault conditions. Purging and reloading the complete operating system is usually the fix unless there is a hardware failure.
Jerry G.
Sep 25, 2008 | HTC Touch P3450 Smartphone
Text messaging
try going into create message, choose new message, choose options, choose text set up and choose TAP english under primary text. then exit, thanks.
Feb 25, 2008 | Motorola Mobility MOTORAZR maxx V6...
Android Apps Logo
50 people viewed this question
Top badoo Apps Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a badoo App Expert? Answer questions, earn points and help others
