Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Hotpoint fridge blocked drain hole - Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Cleaned drain hole
Posted on Jun 23, 2009
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
I have a hotpoint built in larder fridge and keep getting a cup of water at the bottom every day
hi. this sounds like your drain hole is blocked(blow with a straw or net curtain wire)good luck.Ali
Jun 27, 2012 | Hotpoint Refrigerators
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water in fridge
does this fridge have a gulley at the back with a drain hole in the middle? if so, the drain is blocked, push something flexible down the drain till water flows away freely
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Blocked fridge drain
The pan being full doesnt affect the drain being blocked the pans not full anyway its constantly evaporationg it. I use a little air pressure to clear drain lines, than pur a diluted solution of water and a little bleach down the hole water should drain fast and not pool.
Oct 05, 2007 | Refrigerators
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
269 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
