Question about Toys
How do i make coasters from sharpies and rubbing alchol
Cannot see the numbers around dials-is there a picture so I could write them in?
you can search Google with the make and model or call the manufacturer .
Sep 17, 2015 | Cooktops
Headphone dont work
rub the bud the rubbing alchol should help
Oct 28, 2012 | Cell Phones
When i turned my Ps3 on this mornin i changed the disk and put anouther game in. its been doing the spinning line in a circle thing for the last 10mins. it was working fine last night. plz help!
Either bad laser or dirty laser. Take your console apart if you dont have a warranty break down the disc drive metal case and wipe your laser with a q tip and rubbing alchol not to wet though kinda wipe qtip on ur arm to get most of the alchol off the qtip so it wont pour into the laser when you wipe it off. hopefully that works if not its a bad laser.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Front brake pads are not resting on the rim
Getting hand-brakes adjusted correctly is often a challenge, but they are adjustable with the right size wrenches. On the other hand, a front hand-brake on a child's one-speed bike is not necessary and is only on the bike to give it sales-appeal. If this is a one-speed bike, then it has a coaster brake (operated by pushing the pedals backwards). Actually the coaster brake is much safer than a front hand brake anyway. If the child applies the coaster brake too heavily, they will just skid. If they apply the front brake too heavily, they will go over the handlebars. If the hand brake is not interfering with the front wheel and is just not very effective, I would just leave it as-is. If the brakes rub on the tire, you should adjust them so they don't rub the tire.
Jul 23, 2010 | Dynacraft 16" Boy's Wheels Bike
I have a problems about my playstation 2 it is errors
try taking off the bottom of it and clean out all dust and put rubbing alchol on some ear swabs or cottonswabs and rub it along the pannals in the bottom and where you put the game in. hope i helped.
Feb 10, 2010 | Sony PlayStation 2 (PS2) Console
I have a problem with the SNES game ''Illusion of Gaia'' - it won't make any sound at all
This is one of my favourite games!
Try cleaning the cartridge with a q-tip dipped in rubbing alchol...don't drench it...
just lightly rub it over the "little gold things" that you see.lol
Hope this works.
Aug 26, 2009 | Nintendo Illusion of Gaia for Super
Coffee spill
take some rubbing alchol . i mean remove the battery from the camar frist take a soft cloth pour. some rubbing alchol on it where it drippingand soak the back side of the camera let dry for a day or so then try it
Jan 14, 2009 | Nikon COOLPIX L3 Digital Camera
My ps2 wont read the disk. says there is no data. help
it's your laser with something like dust keeping it from reading the discs. Just get a simple CD cleaner kit, one that has the little brush on it and then of course put some solution on it. Rubbing alchol will due. This happens to everyone eventually.
Should do the trick.
If it doesn't do it after playing the cleaning disk three times for around 10 secs each, then you may want to open it up and put clean the laser lens directly with a rubbing alchol soaked que tip and a dry one. For more instructions on how to open it do a search on fixya and there is one guru who goes into great detail about this.
Dec 27, 2008 | EA - Electronic Arts Rock Band
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
Toys Logo
181 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
