Question about Confidence Power Plus Motorized Electric Treadmill
Where can I get a replacement user manual?
I have not used the treadmill for over a year and tried ut today. The screen comes on and reads SAFE with no response from the control buttons
I have a first alert safe bought from costco about 7 years ago. It is a model 7334DFB. It does not want to accept my 6 digit passcode and comes up with 3 beeps. How do I get back into my safe?
hi thomas
after reading your question i found this site help it helps
http://manualzz.com/doc/3151997/first-alert-19-cu.-ft.-gun-safe--user-s-manual
May 20, 2018 | Locks & Locksmithing
DC-6 error on Lifespan Treadmill
Follow attached link to see user manual.
Unplug treadmill.
On page 13 of the users manual, read step 5 part B regarding the wiring harness. Unplug and plug back in each of the connectors of the wiring harness. Plug the treadmill back in to see if it now works. https://s3.amazonaws.com/lifespanfitness/pdf/Manual_TR4000i.pdf
Jul 30, 2014 | Lifespan Fitness TR4000i Folding Treadmill
Trimline manual
follow this steps and fix i.t God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • Sponsored Links
  • 3
    Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4
    Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2gXuRx33v
    Oct 02, 2013 | Exercise & Fitness
    Factory reset code
    follow this instruction and reset. God bless you
  • 2
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
    Tread shocks while using it
    What is the cause for static on my treadmill? Winter is the time of year we receive calls regarding static electricity primarily on treadmills.In fact, many of the OEMs state they expect a certain amount of static, especially during this time of year.
    Listed below are some of the sources which may be responsible for the static problems:
    Items that gyms have control over:
    1. Worn motor brushes
    2. Worn belt/deck
    3. Lubrication maintenance
    4. Lack of humidity in air
    5. Dusty climate
    6. Bad ground
    7. Unit should not be on carpet
    Suggested Solutions:
    1. If motor brushes are worn, replace
    2. If belt/deck are worn, replace
    3. Always keep belt/deck lubricated
    4. Run humidifiers in gym
    5. Keep equipment as clean and dust free as possible
    6. Check ground of machine (power outlet, power cord, drive motor)
    7. Install a rubber treadmill mat
    Items that gyms have NO control over:
    1. Dehydration of user
    2. Dry skin of user
    3. Wool or synthetic materials (nylon, spandex, polyester)
    4. Run pattern of user (shuffling feet vs. smooth stride)
    5. Shoes
    1. Encourage users to drink more water to avoid dehydration (which results in dry skin)
    2. Encourage users to use lotion and drink more water (less friction with hydrated skin)
    3. Suggest users to wear clothing of natural fibers (cotton)
    4. Suggest change in run pattern
    5. Encourage wearing good fitting shoes (old shoes may be too worn causing friction) and shoes without nylon mesh
    It has also been recommended users spray themselves with a product such as Static Guard or mist themselves with a mixture of water and fabric softener to avoid static buildup. Allow for sprayed areas to thoroughly dry before using treadmill.
    Feb 12, 2013 | Precor C964i Treadmill
    Nautilus t514 safe key issue
    1_ reset the machine, disconnect the machine.
    2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
    3) replace and go and buy in homedepot for little price!
    God bless you
    Jul 18, 2012 | Nautilus T514 Treadmill
    Proform 400 ct screen fades out
    Dear Sir:I recomend that you read the instruction manual very well in the troubleshooting section.However you can try the RUN the software calibration for diagnose and troubleshooting. Test the fuse inside, or c. breaker, tight any connector that connect the screen very well.Do not use any extension cord, maybe you can use some stabilizer voltage
    sincerely. God bless you
    May 03, 2012 | Proform 400 CT Treadmill - Treadmills
    Proform 400 ct screen fade out
    Read the instruction manual section troubleshooting very wellif you do not have the i.manuall get for free download www.fitness.manualsonline.com 2) Tight the connector very well going to the screen. 3) See the c. breaker and reset 4) Test the fuse inside from treadmill 5) See my personal TIPS for help 6) Run the software calibration for diagnose and troubleshooting. 7) Do not use extension cord 8) Use stabilizer voltage 9) Measure the voltage input to the machine must be 115/120 vca maximun tolerance 10% +-10( Try to use independt circuit for the machine.
    NordicTrack Z7xi treadmill console buttons not working
    Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
    Good Luck! Tim
    Dec 15, 2009 | Nordic Track Exercise & Fitness
    The User Profile Service failed at login
    Sounds like a vista problem. Have youtried to boot into safe mode? You can do that by oressing f8 during boot up and selecting safe mode from the menu.
    If you can I would try to back up your docs, etc and maybe create a new user account.
    There is also a boot repair in vista that I think comes up with the safe mode menu, so you might try that.
    Hope this helps
    May 04, 2009 | Acer Aspire 5920-6727 Notebook
    Confidence Power Plus Motorized Electric Treadmill Logo
    70 people viewed this question
    Top Confidence Exercise & Fitness Experts
    ray gallant
    Bill Boyd
    Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
