Hello
have a low light setting on my AG-DVX100BP that wont allow the video to show?
Hit the iris button on the side of the camera, then use the dial to dial the iris into an open position and let more light in. Know that the higher the number, the less light coming in, so 16 is just below closed iris, 2.8 is just before completely open iris. The iris is like the pupil of your eye. You should always be in manual iris to control the iris with the iris dial, keeping the video between 4.0 and 6 usually gives you the best exposure (not too hot or too low light.)
You also may have a neutral density filter on. You should only apply this switch if there is too much sunlight. Use nd 1/8th for moderate sunlight, nd 1/64th for bright sunlight. Then adjust the iris with the dial again to get the best picture exposure.
