Question about Hitachi Cw40
What size blade is needed for a hitachi cw40 scroll saw? 5 inch seems too small but that's what they say online...
    Problem Solver:
  • 13 Answers
This saw takes the 5 inch blade. I believe, but not certain the it uses the pinned blades. You can find them at
www.woodenteddybear.com
As well as other sites. You can Google 'scroll saw blades' and find other merchants where blades are available. Do not use box store blades as they are too big for most scrolling needs
Posted on Dec 18, 2014
  • 30 Answers
Posted on May 07, 2014
Testimonial: "the 16 inch refers to the depth of the saw from blade to throat (or back), not the blade. i'm having a hard time locating a 6inch blade for my saw"
I have a 12" dewalt miter saw. I put a new blade on and now at startup it makes a real loud noise.???? Took the blade off doesn't make it even bought a new blade no luck. Any answers??
Just a thought; maybe your saw requires a 300 mm blade rather than a 12 inch?
The popular view is the two sizes are interchangeable but there is a small difference in diameter with the Imperial blade being about a quarter inch bigger than the metric.
I had a similar problem with an eight inch saw. When I fitted an eight inch blade it seemed to be ok but when switched on it made a loud noise, similar to yours I guess.
I was unwilling to buy another blade so I modified the saw to give the blade housing a little more clearance so I could use the eight inch.
Jan 17, 2016 | Saws
What size blade do I use on a performance tough 18 in scroll saw?
Scroll saw blades I've dealt with are all the same size--just the tooth count per inch--need more info.
Aug 21, 2015 | Saws
How to install blades
Almost all scroll saws use a 5 inch blade. You need to take all the tension off your saw before installing the blade. Make sure you are using the right kind of blade. Either it is a pinned blade or non pinned blade. Some saws can use either. Make sure the teeth on the blade is facing down toward your saw table. Clamp the blade into the blade clamps and then add the tension. You should be ready to go now
Jul 12, 2014 | Saws
Brand new out of box but the blade touches the insert but also seems to touch the metal base at the dust funnel. Is there an adjustment somewhere? None obvious in manual.
Check the size of the blade as it is probably 1/2 too big for the saw
The correct size blade will have a diameter that will give sufficient clearance for that machine.
Feb 09, 2013 | Hitachi C12RSH 12" Sliding Compound Miter...
Table wont lock into position..lock knob wont tighten all the way down
Here's a link to Hitachi Customer Support. At the bottom you will see their phone numbers. Maybe they can assist: http://www.hitachipowertools.ca/en/CustService
Feb 05, 2013 | Hitachi Cw40
Working on a plank 5' long 10"depth a thickness of 1.5" will a scroll cut into this hollow plank to a depth of 5"then go across 1.5"then return 5"
Cole, The cut you are describing is challenging, but possible on a 20" scroll saw. First the blade--- you call this a hollow plank. If this is something like a hollow-core door, then the 1.5" thickness will be no problem. If you have to cut through a solid 1.5" (as you would at the edge) then you have a slow go of it unless you can find a pretty coarse pitch blade (big teeth). Second, making the turn----- assuming you are making this cut somewhere near the center of the 5' lenghth, then you won't be able to simply make a 90 degree turn after you cut the initial 5 inches. But you can make an approximately 60 degree turn, then stop the saw, leave the workpiece in place with the blade still in the cut, and reset the blade to cut sideways (so that the teeth of the blade are facing to your left or right rather than pointing toward you.) Before you make this blade turn, however, you should make the other 5 inch cut, so that you don't have to make the blade turn twice. Alternatively, if the 5 x 1.5 piece you are removing is just scrap, then you can make your two 5 inch cuts just converge to a point at the middle of the 1.5 inch line so that you can remove most of the scrap without moving the blade. Then you can reset the blade more easily with the workpiece removed from the saw. I hope you found this helpful.---- Oh, one more thing! The 1.5 inch part of the cut would be a lot easier simply by using a coping saw - they are about $15. Actually, you could do the whole cut with a coping saw. Good luck! Al K
Jul 29, 2011 | Dewalt DW788 Heavy Duty 20" Variable Speed...
We have a master craft 12inch maximum dual bevelmitre saw with laser, came with a 12 inch blade with a 5/8 arbor, apparently they don't sell 12 inch blades with 5/8 arbor, only 1 inch. apparently saw...
You need a saw blade bushing. It looks about like a wedding ring with a 5/8 id (inside diameter) and a 1 inch od (outside diameter). I did a quick google search and found this: http://circlesaw.com/xcart/1-to-5-8-Saw-Blade-Bushing-p-5036.html
Good luck. Please vote if you found this helpful.
May 27, 2011 | Garden
Circular saw Types
There are for types of circular saws available. 1. Worm Drive - The motor is in line with the blade, delivering enough torque to carve up wet lumber or saw through concrete, which makes a worm drive ideal for framing or major renovation jobs. With the handle farther back, a user can better resist kickback and steer the 16-pound saw through long rips. 2. Sidewinder - The motor sits alongside the blade, making for a lighter (11 pounds or less) saw, which is more maneuverable over a long day than a worm drive. 3. Small Sidewinder - Weight, balance, and handle size are all key features to consider when choosing a saw that fits you. For a slight-bodied person, a small model may be more appropriate than a full-size sidewinder. 4. Cordless - Battery-driven models have increased in size as their power packs have gained voltage, making them convenient tools out in the field or when the electricity's not on. However, cordless models still have limited run times and generate less torque than corded saws. 5. Trim Saw - For finish work or paneling, this is your best choice. blades range from 3½ to 412 inches.
Aug 27, 2008 | Makita 794520 1 5 Pack 5" X 120 Grit 8...
Hitachi Cw40 Logo
1,294 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
