Question about Mth Z-4000 - 400 Watt Transformer
Nothing happens when left hand throdle is raised
Johndeer la140 runs good on full choke but throdle lever does nothing it is not broke the butterfly is moveing in the carb but no gas response runs good on full chock but when i put the choke down ...
WHEN YOU GIVE A CARB CHOKE, IT RESTRICTS AIR FLOW AND GIVING THE ENGINE MORE GAS INSTEAD OF A REQUIRED MIXTURE... USUALLY THIS IS FOR STARTING IN COLD TEMPS. UNTIL THE ENGINE WARMS UP AND YOU RETURN THE CHOKE BACK TO NORMAL. THAT IS ALL THE CHOKE DOES.... IT DOES NOT MAKE THE ENGINE RUN BETTER BECAUSE YOU THINK IT WILL.
Jan 06, 2015 | Garden
Waverunner won't go faster than 12 mph with 2 passengers under max weight limit
are you getting full throdle does it rev up all the way , if so look over tunnel for obstructions NEVER PUT YOUR HAND IN THERE , SAME FOR REAR OF JET PROP AND BE SURE MACHINE IS SHUT OFF ., what happens over time is the blade and rear nozzle become woren out along with metal ring surrounding jet prop replacement cost is about 250.00 but its worth it once fixed you'll thing you got a rocket. my experancy I did my two jet skis this past spring .good luck I really hope this helped .Woody
Aug 08, 2014 | Cars & Trucks
Seat height adjustment
Hi
There should be a set of levers on the right hand side (left hand if you are on the left). one of these will move the seat back and forth, one will raise and lower and one will move the seat back.
Some of these rise and fall levers are a "pump action style" where you push down to get the level or pull up.
Other type will raise the seat fully either up or down. Its on a cam.
I have had these seize before and have had to replace the mechanism.
Cheers
Roger
Apr 21, 2014 | 2006 BMW 318 Ci
Feed dog is in down position and cannot be raised.
lower it again and when raising it jiggle the hand wheel a little. That should get it engaged for you.
Mar 14, 2013 | Sewing Machines
What happens if you don't have enough chips to call a raise?
If you don't have enough chips on thetable to a call a full bet, you can still call it, and you just can't win anyof the pot that's beyond your bet amount (the amount of chips you have timesthe number of player in the game plus the people who have been in the hand andfolded before you). When there are only two people left, you just reduce thebet amount to whatever the guy has. I myself had encountered this scenario afew times and the math is pretty simple and intuitive.
Jul 23, 2012 | Furniture
I was sewing and all of the sudden, the bottom thread became tangled . I have tried to rethread and clean the bobbin scuttle area. Nothing works.
This is usually caused by lack of top tension or threading the machine with the pressure foot down.
-Set the top tension dial to 5
-Raise the pressure before threading the machine
-"floss" the thread by holding the thread as it comes off the spool with your right hand and holding the thread right before the needle with your left hand.
Make sure to do that with the pressure foot up. What happens is sometimes the thread doesn't go into the tension discs all the way due to lint or something else.
With the pressure foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
Jun 13, 2010 | Brother CS-8060 Computerized Sewing...
Raising a number to a power
You use the ^ (caret) button, which is on the left hand-side to the left and up one from the 7 button.
Press 9 then ^ button then 23 and the equal button.
Jul 09, 2009 | Texas Instruments TI-30 XIIS Calculator
Transmission (auto) not shifting
Governer or Transmission module.
Apr 20, 2009 | 1995 Ford F250
Board is reading 'left' and right backwards
Note that the blue light on the Wii Fit board should be facing AWAY from the TV.
This should fix your problem right away.
Jan 30, 2009 | Nintendo Wii Fit for Wii
I need advice asap about lexmark1185
My lexmark x1185 should be trying to print the envelope on the very right hand side of the entrance. However, when I lay the envelope on the right hand side of the entrance it will not print. The printer is typing on the left hand side of the entrance (the left hand side of a regular size paper). I cannot find how to change this problem. Please help
Jan 22, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Mth Z-4000 - 400 Watt Transformer Logo
74 people viewed this question
Top Mth Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Mth Toy Expert? Answer questions, earn points and help others
