Question about Raymarine Boating
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their website said to allow a few days. The part number is M78874, I want toknow if I can still get one or whether their is a compatable unit. Thanks for any help you are able to give. kind regards Andrew
I have a new one. If you still need one, please contact
nakdogan@t-online.de
Posted on Oct 21, 2010
I happen to have a transom mounted 530 transducer with the cord and connection but I have removed the wheel for use on my Apelco 360 transom mounted transducer. I'd be willing sell it without the speed senc\sor wheel. You would still have water depth and temp. and maybe the GPS portion of the unit reports speed.
Bussd' Outlet
Posted on Sep 12, 2009
My 530 head set was broken and I do not plan to remove the transom mounted transducer. If you still have not found M78874, can you sell me the head unit and power code? Thank you.
Vince
Posted on Aug 14, 2009
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Posted on Jul 23, 2009
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
Why is Raymarine DS500x screen browning?
Typically I have seen this for units that have been overheated - such as left out in direct sunlight when not in use.
Jul 07, 2014 | Raymarine Ds500x Color Fishfinder: Ds500x...
I need a new power cable for a raymarine DS500X fishfinder. Where is a good place to buy?
Contact Raymarine or your nearest Raymarine dealer. Raymarine normally has those things on their website although it's a bit cryptic to find sometimes.
Jan 18, 2010 | Raymarine Ds500x Color Fishfinder: Ds500x...
Raymarine ds500x brand new works good but will give false bottom readings occasionally corrects itself fairly quickly 30 seconds to two minutes wondering why it does this and how to correct it
If the transducer is not correctly mounted this may happen due to air, etc. If the unit never gives a depth reading that looks like dashes
( - - ) then there is likely nothing wrong with it aside from the transducer placement.
Aug 06, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
Screen fog
Hi there... mine did the same the very first morning I took it out. I rang and sent it to the manufactures. It was a very common thing and they fixed it within 10 days. I have not had a problem since. It should not of happened in the first place though. I have read a heap of forums on this exact matter and i think you would be the 10,000 person with this very problem. I have also had big problems with my transducer... so overall I am not impressed with Raymarine.
All the best mate.
Jan 02, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Boating Logo
982 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
