Question about Garden
Mower won't start
Was running and a root was hit and mower will not start. It ran for a while and vibrated bad. But now it won't run at all.
  • 93 Answers
If this is a push type mower, most likely is has sheared the flywheel key and bent the bent blade caused the vibration. The blade will need replaced and likely the flywheel key.
Posted on Jun 02, 2014
hunter19_46m
  • 7482 Answers
SOURCE: Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
Posted on May 26, 2010
Testimonial: "Your response was very helpful. Is there a repair manual or instructions online that I could get to describe the process to repair the mower? Again thanks for your response. "
  • 407 Answers
SOURCE: i hit a root now
Sounds like you bent the shaft.Or bent the blade.Check the blade first.If it is bent then replace it.If not then you may need to replace the shaft.
Posted on Jun 18, 2011
#1 Taper
  • 1040 Answers
SOURCE: I have a Poulan push
If you are sure the oil level is correct then it sounds like it's about to die, unfortunately. A pine cone shouldn't cause any damage, but a large branch may do so. Was it smoking before you shut it down? The vibration could be caused from a bent blade. It could also be caused from a part breaking in the motor. I wish I could have given you better news!
Good Luck,
Jim
Posted on Aug 13, 2011
SOURCE: Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Posted on Jun 30, 2012
  • 6468 Answers
SOURCE: mower was running hit tree root mower quit
check the key on the flywheel where it meets the crank shaft it shears when this happens very very common
Posted on Jul 11, 2012
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Mower was running hit tree root mower quit
Jun 22, 2012 | Craftsman Garden
The mower vibrates a lot
Either the blade is badly out of balance/bent or it has hit something hard enough to bend the crankshaft which I have seen happen quite a few times. It could also have sheared the flywheel key causing the engine to be out of time but usually when that happens they won't even start and run.
May 18, 2012 | Garden
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Mower starts but won't stay running
check the inside of the cap. Check the underside of the gas cap for a cardboard disk. Remove the disk, and try starting again. My mower had same problem, and I removed the disk and suddenly it ran like there was no problem at all.
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
I have a Poulan push mower that after mowing in a ditch started making a loud noise and running rough. It almost sounded as if metal was hitting metal. The mower was vibrating more than normal. I checked...
Good Luck,
Jim
Aug 13, 2011 | Poulan "Poulan" Push Mower
Black & decker MM 850 Electric Lawn mower/mulcher. Upon start up, there is major vibration. No way I can run it like this..
Try removing the blade. If the mower runs smooth, replace or balance it.
If not, the mower shaft may be bent. Did you hit something hard with the blade?
Gary
Aug 11, 2011 | Black & Decker 19" Electric Lawnhog...
I have a husqvarna self-propelled lawn mower/keystart with leaf bag. i hit a small tree root and now it wont start. the cord back fires a little when you pull it. will a bent blade stop it from cranking?
Hi hardister2...
Sounds like you sheared the key that holds the flywheel to the crankshaft, this is a common occurance when you hit something hard with the mower running.
You will have to remove the flywheel to replace the key.
No a bent blade will not stop the mower from running,but should always be replaced
It can cause problems later with the seal under the mower, it will start to leak oil.
Please take time to rate me
Jun 28, 2011 | Husqvarna Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
