Question about Sony KP-48S65 48" Rear Projection Television
Is 16 year old sony worth repairing
Tv blinks in and off
4 Suggested Answers
SOURCE: Sony Rear Projection KP-41S4U
change the rgb ic thats the stk ic
Posted on Nov 07, 2007
tracy_a
SOURCE: Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: Sony KP-51HW40 rear projection TV - green screen then no picture
Check this link it will (should) resolve your issue.
Posted on Jan 02, 2009
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Hi No picture
It is 16 years old TV and I do not think that spare parts would be available any more so think about new TV instead of repairing this TV.
Thanks.
Sep 11, 2009 | Sony Televison & Video
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
TV Turns self off- 4 blinks on standby light
Yes, the blinks are error codes. I would not bother trying to figure out what they mean, I can tell you right now. Expensive repair. Average repair costs are 1/4 to 1/2 of the TV's current worth. Most likely a bad transistor. The average expected life span of a TV set is 3-5 years. After that, stuff starts wearing out fast. Time to move on.
Nov 14, 2008 | Sony KV-28FX60 28" TV
Sony Trinitron Model KV-27S10
If hte set is a Sony, the standby light should be blinking a code. Report that code here and we should be able to guide you. That code will indicate the problem circuit within the set that has the fault.
Thanks,
Dan
Jun 02, 2008 | Televison & Video
Is is worth getting repaired?
Power supply mnay be out. Yes, get an essimate if you like first, but if it's less than 8 years old-get it fixed.
May 05, 2008 | Sony KV-32FX60 TV
Sony KV-32FV26 32" TV
5 LED flashes is a CRT drive problem (IKR) CRT is poorly set G2 volts wrong or the CRT is exuasted. Either way you need an engineer and an estimate on the cost of repair.
Feb 12, 2008 | Sony KV-32FV26 32" TV
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
12 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
