Question about Kyocera Color Copier, Km-c2525e
How can fix the error message c7104 in Kyocera c2525e
The yellow color was not coming out well so I remove the toner cartridge to check it and there after the copier began to show the c7104 error message. So what should I do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 150 Answers
This code is saying you have a bad yellow dv unit you have to have a new 1
Posted on May 07, 2014
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
idriss47
  • 26 Answers
SOURCE: Kyocera mita 1810 copier error codes C and 620
do this cervic code : "163"
Posted on Feb 06, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
acdr
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
  • 66 Answers
SOURCE: Copier fixing problem
Hi
The A-3200 error indicates a scanner lamp problem.
It can either be a loose connector or more likely a lamp or inverter PCB.
Another cause can be incorrect shading position, by moving the contact glass this may fix it.
Posted on Jul 15, 2009
What can I to clear the c7101 error?
you have a code saying 1 of your developers is bad
May 08, 2014 | Kyocera Color Copier, Km-c2525e
Xerox DC12 Error code 9-355
Error code 9-355 indicates, the magenta toner dispenser is broken and in need of repair.
Open the Front Door
From left to right, the Toner Cartridge colors are Cyan, Magenta, Yellow, and Black.
As a pre-caution, place a few sheets of paper on the floor, under the Toner Cartridge area, to catch any toner that may spill.
Remove the Toner Cartridge by rotating the handle to the left until the handle is in the unlocked position.
Pull the cartridge completely out of the machine.
Check for any obvious damage in the cartridge or printer and reinstall. Replace cartridge if damaged.
If error message continues, call a qualified repairman.
I hope this helps you fix your printer.
Jan 28, 2011 | Office Equipment & Supplies
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
My Ricoh CL7000 keeps asking to replace the yellow toner, which I have done and it goes through the motions of loading the toner then the error message comes back again - asking to replace the yellow...
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
Jun 11, 2010 | Ricoh Aficio 1035 Copier
Copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Aug 14, 2009 | Kyocera Office Equipment & Supplies
Hp color laserjet 3550 - error message "cartridges not engaged"
here are the codes for the error you are getting
10.92.00 Black toner
10.92.01 Cyan
10.92.02 Magenta
10.92.03 Yellow
The fix is either the toner lock is broken. Contacts on the left side of printer are damaged.
There is a complete proceedure for replacing the the toner locks which comes in a kit you can order from precisionroller.com. this takes about an hour.
If the contacts are damaged you will have to replace the whole plastic part on the left side behind all of the electronics. It takes about an hour
Jun 14, 2009 | HP Color LaserJet 3500 Printer
Toner Problem error message
remove the yellow plastic from the toner thats a protection. check around toner.
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
Error 2408
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Kyocera Color Copier, Km-c2525e Logo
634 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
