Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn Air range, model F-121, backsplash light doesn't work
We have an older Jenn Air range, model F-121, and the backsplash fluorescent light will not stay on. It comes on but goes off almost immediately. The bulb and switch have been replaced, but that didn't fix it. Could it need a new ballast? Where is the ballast located on this model?
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
SOURCE: Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
SOURCE: Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Posted on Nov 27, 2009
Where can i find the fluorescent light ballasts for my hood?
They may not be sold separately, but you can use any ballast you want as long as the ratings and wiring is the same and you have room to mount it without any interfernce.
Jul 14, 2014 | FiveStar FSH481SS 48" Wall Mount Range...
An older jenn air grill range model # S125- the left burner does not work front or back and the light stays on
Replace the switch that controls one of the two burners. One switch is bad. Look also for a blown fuse. if present.
Chances are one bad element had shorted out the switch (now stays lit) and also took out one fuse.
Oct 20, 2013 | Jenn-Air Kitchen Ranges
I am trying to convert a Jenn-air model # PRD3630NP from LP to NG I assume this model is convertable becouse it has a convertable reg on it. Do thay make a kit to do this or is it just a matter of ins
Jenn Air use to make a kit that had the proper orifices for the burners and the valves. The regulator is adjustable for the conversion by simply reversing the main screw. It was intended to be convertible. However, since the model is discontinued, you can no longer purchase the kit (or the backsplash). Apparently Jenn Air believe that when they stop making a product, no one will ever need a part for it again (cough, cough).
Good luck trying to track down a kit. I've tried everywhere in the country and a few shops in Canada. I have a gas appliance expert who thinks he can accomplish the conversion by getting a few of the parts from the LP model and then modifying the rest. The orifices are basically the same, only the LP diameters are different. Theoretically, the ports could be filled and redrilled, but the hardware store was fresh out of 1.07mm bits, so I'll pass on trying this on my own.
If anyone has a LP model they want to convert to natural gas, I'll gladly swap parts.
Jul 25, 2012 | Jenn-Air Kitchen Ranges
Broken older jenn air front glass oven panel
We are Jenn-Air parts suppliers and have access to parts for your range. Please record your model number from underneath the unit by looking inside the cabinet.
Then contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM unti 7 PM CST and we will give you the price and availability of this front glass.
We look forward to hearing from you. Thanks, Ella
Jan 21, 2010 | Kitchen Ranges
I do not have the stainless steel backsplash, I had a custom stainless steel piece made that keeps the back flat into tile. When I am using the burners, and than turn on the oven, the burners go out and...
backsplash will not cause a problem unless this was the only open air space of the oven, if both left and right and back of oven are closed, this may cause a shortage of air to the oven. half inch to right and left of oven should be enogh. let it breath.
Sep 03, 2009 | Jenn-Air ® 48" Professional Over The...
Jenn air model JDR8895
the cord may not be securely fastened at the terminal block when you pulled the unit out it could have pulled one of the connections loose check the cord for good connection at the terminal block and if the top is working like mrappliance asked then you have a problem with the board or wiring to it but with the recent movement of the unit I would start with the power cord
May 09, 2008 | Kitchen Ranges
Jenn-air electric range
does the unit have a lever or does it lock automatically from inside the panel?
Jan 03, 2008 | Maytag MER5775Q Electric Kitchen Range
Jenn Air Older Oven wall unit only
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Jul 08, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
178 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
