Question about Maytag Refrigerators
Our Maytag fridge has the freezer on the bottom and the fridge on the top. The fridge part is not staying cool. We were told to unplug for a day and we did and now 2 days later it is doing it again.
    Brigadier General:
  • 3,917 Answers
There are a couple of troubleshooting steps to be done before going ahead with any part opening or replacing.
1) check Freezer to see if there frost on back panel toward the bottom. Open up panel reveal coil was freeze over.
That confirm diag.
2) On Refrig side. Open top control panel. right side toward the end ...there is a piece of electronic. un-plug and plug in new part.
3) Defrost freezer and everything is working again. Fix alone is 5 mins for the unscrew and replace an open electronic part. In my opinion, this is a bad design. There is moisture in refrig and they left this piece of electronic in the open. There will be a short, it's just matter of time.
http://www.applianceaid.com/frig_notcold.html
Remove power, remove freezer back wall, check defrost heater and defrost thermostat, remove covers in FF section and replace adaptive defrost board and then defrost the frosted up coils in the freezer and reinstall the covers
Thanks for contacting Fixya
Posted on Jun 22, 2009
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Bottom freezes, and the top doesn't stay cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Maytag Refrigerators
Getting where it doesnt cool. but after unplugging it for a few days it cools again.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 12, 2010 | Maytag MTF2156GES Top Freezer Refrigerator
Warm fridge
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Maytag MB2262H Stainless Steel Bottom...
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com
Defrost system problem; Check back wall of freezer for frost buildup which indicates the defrost problem.
Jun 20, 2008 | Maytag MZD2766GES Side by Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
