Question about Whirlpool 4318083 Start Relay
WHAT DOES A 4318083 START RELAY DO - Whirlpool 4318083 Start Relay
    Genius:
  • Whirlpool Master
  • 1,363 Answers
It provides power to a fan, contactor, etc by allowing a low voltage to control a higher voltage source
Posted on Sep 06, 2015
The start switch start the dryer but shuts itself when we release the button
Several different components could be preventing your dryer from continuing to run when the start button is released. The wiring diagram and other technical information for your dryer are shown in the image below. When the start (PTS or Push To Start) button is pushed, the PTS contact is closed and voltage is supplied to the drive motor. Start voltage is also sensed through the blue/black wire that is connected to the P1-5 Start Sense pin on the control board. When the control board senses the start voltage, it normally applies 48 volts DC voltage through the Pink/Black wire to the motor relay to hold the contact closed between the two blue wires attached to the motor relay that supplies normal run voltage to the drive motor. With the start button taped down, the motor continues to run since it gets voltage through the closed start button. Since the motor stops running when the start button is released, it indicates that you have one of these 3 failures:
Broken or disconnected Start Sense wire.
Failed electronic control board that is not sending the 48 volts DC voltage through the motor relay Failed motor relay. Wiring failure between the components.
Since the motor relay and the heater relay are both exactly the same part, you could unplug the dryer and switch the motor and heater relay to see if the dryer will stay running. If it does, then you just need to order and replace the bad relay.
Jan 05, 2017 | Dryers
I changed my starter in my 2007 pontiac g6 it still won't start. I checked the battery and the alternator both good. Help!
Is there a SECRUITY light lit on your instrument cluster ? Did you check the starter relay in the under hood fuse / relay center ?
For ignition switch power modes refer to Body Control System Description and Operation . Once the ignition is placed in the Run/Crank position, the control circuit of the Run/Crank relay is grounded by the body control module (BCM). With the Run/Crank relay switch closed, battery positive voltage flows through it and on to the park/neutral position (PNP) switch. With the PNP switch in either the Park or Neutral position, battery positive voltage will flow to the START relay coil supply voltage input terminal of the engine control module (ECM) and the coil side of the START relay. Placing the ignition in the START position sends a message to the ECM requesting engine start. If the ECM has determined that the transmission is in Park or Neutral and theft is not active, it will supply 12 volts to the control circuit of the START relay. Battery positive voltage will then flow through the switch side of the START relay to the S terminal of the starter solenoid, cranking the engine.
I suggest you take this to someone knowledgeable in new car electronics . There is a lot going on here , modules talking to each other on GMLAN serial data communication network . If no anti-theft system problems The BCM sends a message to the PCM on the GMLAN telling it to energize the run / crank relay ! If you knew vehicle systems you could check for power an control of the start relay right at the relay base / socket !
VEHICLE RELAYS Operation Diagnosis
Jul 24, 2015 | Pontiac Cars & Trucks
2003 mitsubishi eclipse rs wont start i already repalced the starter...where is the starter relay at
The relay is located in the relay box under the hood in the relay box. I suggest you Google "relay location 2003 Mitsubishi Eclipse" for the exact location. For troubleshooting purposes, once you locate the relay, simply swap it with an identical relay within the relay box. If it still fails to start, then it is not the relay.
Apr 11, 2014 | 2003 Mitsubishi Eclipse Coupe
Turn the key all lights go on but nothing happens when you try and start it
1. Make sure your battery is fully charged.
2. Check connections from battery to starter relay.
3. Make sure you have voltage going to the start side (small wire) of the relay with the key in the "start" position.
4. If you don't have voltage going to the start side of the relay (small wire) with key in the start positon, then your starter switch is faulty (under dash usually mounted on top of steering column).
5. If you have voltage to the start side of the relay (small wire) with key in start position, and it don't click when trying to start your car, then the starter relay is bad.
6. If your starter relay clicks, but engine don't turn over, then the starter is faulty.
Dec 09, 2013 | 2000 Buick LeSabre
Engine wont turn
Dec 09, 2013 | Cars & Trucks
Started relay in a 1999 Altima
Dec 08, 2013 | Cars & Trucks
1999 cougar, brand new battery and terminals. It will not turn over. It won't even click anymore.
Relay switch
arnie, use either of the spades on the right side and you should be good to go. thx peyton.
Jan 25, 2009 | Freezers
Freezer has quit working and now refrigerator not cooling like it should.
If you hear the start relay clicking after the compressor tries to start then you know that there is power to the compressor.
This tells you it is ether a bad start relay or a bad compressor.
At this point I use a meter to see if the compressor is shorted to ground.
If the compressor is not shorted then replace the start relay and give it a try.
You should hear the compressor start right away with a new start relay if that was the problem.
If the compressor is shorted to ground you will need to have the compressor replaced.
Given the history on whirlpool refrigerators in the 5 year old age range It may be good chance that a new start relay will fix your refrigerator.
If the start relay is bad you will hear it try to start the compressor and then click off.
If the relay is bad you will hear the clicking sound seconds after plugging it in and then again every minute or two as it keeps trying to start the compressor.
Jun 02, 2008 | Whirlpool Refrigerators
Whirlpool 4318083 Start Relay Logo
43 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
