Question about InFocus Proxima UltraLight LS1 Multimedia Projector
The power will not stay on - InFocus Proxima UltraLight LS1 Multimedia Projector
How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
Jan 31, 2018 | Vizio Televison & Video
Why isn't it powering up and all lights are staying on?
Check all the cables and make sure that they are plugged in tightly. After that I can't help you without more information.
May 11, 2015 | Siemens Speedstream 4200 Modem
Battery light stays on car loses power, battery won't stay charged
check charging system like altenator or make sure battery cables are clean and tight. go to advance or autozone they will check it for free.
Jul 09, 2012 | 2008 Dodge Avenger
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
BOSS DD3 STAYS ON AND WILL NOT TURN OFF
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
Oct 08, 2009 | Boss Music
Power light on, but not responding
just wait till the battery power gets full.
Sep 24, 2009 | Computers & Internet
Power button will NOT stay in / ON
please check with cord connected to computer
Mar 25, 2009 | Audio Players & Recorders
Just got Verizon 755p - can the power stay on while charging?
Try StOIC (Stay On In Cradle):
http://mytreo.net/downloads/stoic-stay-on-in-cradle,221.html
It's free and it works - the screen will stay on whenever the Treo is connected to charging power (e.g., in the cradle).
Enjoy!
- IntelelctArsenal
Jan 18, 2008 | Palm Treo 755p Smartphone
InFocus Proxima UltraLight LS1 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
