Question about Dell Inspiron 5100 Notebook
I turn the power on and it comes on but when i press main windows it dosnt load it just sits there forever
  • 331 Answers
Reboot and hit the f8 key as soon as the computer starts. pick start in safemode with networking. right click on my computer and select manage. goto event veiwer and goto system. and look for exclamation point. then get back to me. also check the logs for security and applications. post anyy errors. post your version of windows also please
Posted on Jun 22, 2009
  • 90 Answers
I assume you are reffering to trying to login to windows and it will not load when you try to login to an account. To fix this the best way usually is to clear the profile. To do this restart the computer in safe mode. If you can get into windows that way go to c:\documents and settings\%user% (the name of the account you log into. and rename that folder with the account name with a .old at the end. This will cause your computer to recreate it at login which usually clears up issues like this. If that works go back into the profile you renamed .old and copy you desktop icons etc out of it and into the new profile it created.
Dosnt turn off says on but if you press any button it just beeps
bad control board maybe u can reset the applaince? try turning to off position pull out knob then unplug for a couple minutes then plug back in then lift open and close lid slightly 6 times within 12 seconds - good luck
Jul 10, 2014 | Hotpoint Ultima WF860 Front Load Washer
Error 5200
  • down load the file fon the following sit
  • http://www.ziddu.com/download/11944259/PCM_servicetool.rar.html
  • Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
Aug 05, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
I turn on my computer. it starts to boot. then blank screen. nothing. it dosnt load into windows nothing. even my mouase dosnt work but it's on
Turn off computer. Now turn it on, and as it is starting hold down the F8 key. you will hear a beep and ket it go. A set of options will come up and choose Safe Mode with Networking. if it manages to get to windows you are fine.
If not, hit fn key + a key with a smzll monitor (usually one of the F keys at the top, like F5 or F6). It might have been put on display mode and woukd onky show if connected to a projector, tv, or external monitor.
Apr 02, 2011 | HP Computers & Internet
Screen stays black after windows loading screen
Just do static discharge.
Turn off notebook - take out battery. unplug from mains. press and hold power button button for 20 seconds. Try and turn on notebook again
If that will not work. Just keep pressing f8 key after you press power button. YOu will see advanced boot menu. In advanced boot meny select safe mode. Check if you cal load windows in safe mode. If yes then do system restore from (Start-all programs->accessories->System tools->System restore
thanx
Oct 12, 2009 | HP Mini 1000 Netbook
My HP Pavilion DV9000 is having boot up problem
hi
this is nothing to do with system crash.
> Take out the battery and the adapter from the notebook hold the power button for 30 sec
> Power on - ASAP tap on F10 - There if you are using vista press F9 to load the bios defaults and press F10 save and exit
With regards
Apr 12, 2009 | HP Pavilion dv9000z Notebook
Won't turn on
unplug the main power to the power supplie.take the batterie out from the motherboard.
plug it back in.
turn it on.
replace batterie .
if this dosnt work your power supplie may have died randomly.
Mar 03, 2009 | Dell Dimension 3100 PC Desktop
Sony Vaio VGC-RC024 will not boot up
Try when system is booting up, press F8 to come into boot choices.
Select last known good configuration.
select OS
if it still hangs try F8 again on boot and go into safe mode,
If neither way works the master boot record may be corrupt or viruses may be preventing boot up.
Mar 31, 2008 | Sony VAIO® VGC-RC310G PC Desktop
My maing image fails to load
what you should try to do is plug the sandisk in your computer then put the sandisk on hold and hold down the menue button till it says its in recovery mode.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
Dell Inspiron 5100 Notebook Logo
55 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
