Question about Fuji FinePix S2000hd Digital Camera
S2000hd batter door. One of the little plaastic "clips" on the canera body that the battery door latches into has broken and the door does not stay closed the way it should. Fuji tells me no warranty, body replacement. ???????? Any suggestions?
  • 94 Answers
Get a piece of flat aluminium or steel approx 2 inches long, drill a hole at one end and use the Tripod socket to hold the flat steel down, over the batery lid to hold it shut.
Posted on Jun 01, 2010
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The battery door hook which is situated on the body is broken. It seems the hook (latch) is molded on the battery compartment (body) How can I fix this. I am fond of this camera and I have the full...
If you have all of the pieces, you can use crazy glue to make the repair, otherwise take your camera to any camera shop where they will have access to whatever broken components need to be replaced. Regards, Joe
Nov 13, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Cannot remove the battery from by new nikon d300
Hi Dee and thanks for coming to FixYa.
Hold the camera like your going to take a picture. Now turn the camera over to look at the bottom. On the right hand side is a small latch. The latch secures the battery hatch door. Pop the latch and the battery door should open.
Turn the camera back over carefully and the batter should slide out.
Then plug the battery into the charger and you can charge it. Have fun with your new camera!
Rob
Feb 28, 2009 | Nikon D300 Body Only Digital Camera
Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Oct 07, 2008 | Kodak EasyShare DX7630 Digital Camera
Bosch SHU43 / Siemens Dishwasher door not locking
I replaced the top cover, that required removing the door screws to get access to the front of the door to remove the 4 top cover retaining screws. After replacing all this, the door latch was in teh locked position not allowing the door to close. How do you physically re-set the lock, I tried to push it with no luck!
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Fuji FinePix S2000hd Digital Camera Logo
263 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
