Question about Refrigerators
Ice on refrigerator ceiling - Refrigerators
  • Refrigerators Master
  • 4,655 Answers
That is a sign of a defrost problem. You can find the model numbers located in places in photo below. If Sears model the number will look like 213.56498 for example. ..Sea Breeze
Posted on Jun 22, 2009
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
True GDM-33 refrigerator icing up around the condenser then defrosts leaking water all over the floor.
It could possibly be an issue with the thermostat not shutting off. I would set it at it's setting to see if it shuts off. If not replace the thermostat. Also check to see if the evaporator fans are running.
Oct 29, 2017 | True GDM-33-SSL-54 Refrigerator
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
I have a model # RB170TM. I don't know how old it is. We have ice on the inside ceiling of the refrigerator, and it only will cool to 50 degrees. The freezer sometimes freezes ice cream too hard, and...
Check the gaskets and make sure they are sealing properly. Old trick close a dollar bill when closing door then try pulling it out. You should have some resistance. This should solve frost on ceiling of refrigerator.
Next check the defrost by advancing time clock. Sounds like you have an intermitten defrost .bobicehouse.jpg
May 15, 2011 | Magic Chef Refrigerators
Looks like water dripping from frezzer, but there isn't an ice maker hooked up in the freezer. top refridge shelf covered with water and ice
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
Jan 23, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Model # 795.75286.402 Motor running load
The evap fan motor most likely is running loud due to a ice build up around the fan and the fan blade is hitting it and making a loud , irriting noise. Shut the ref off. If you are mechanical, remove the draw and the back cover, clear out the ice. Also, the ice may have been caused because the sensors-- thermistors--- are not located properly. look at the ceiling of the freezer and you see a small holder piece. the part is located there. tahke the cover off and take the thermistor that may be buried in the ceiling and pull it down and locate it in the holder, reinstall the holder. Not also, there is another one in the ref section to do the same thing
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
