Question about Samsung SafeVIEW Baby Monitor
What makes the desktop show the message "no signal" and won't come back on without rebooting, yet the light is on the hardrive
What causes the desktop to show the message "no signer" and won't respond without rebooting, yet the light is on the hardrive?
Verbatim 1tb external hard drive turning on
Make sure the appropriate drivers are up to date:
http://www.verbatim.com/index/support.php?lang_id=1&cat=9&section=
Try different ports on your machine, reboot your machine, try connecting it to a different computer if possible.
Type in diskmgmt.msc into the search bar, and see if the drive shows up here at all. If it shows up, but doesn't have a drive letter right click and use the assign drive letter option.
Contact verbatim for a replacement cable.
May 29, 2013 | Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
I have a dell dimension 3000 series desktop and when I turn it on it does not get passed POST and tells me the following: primary drive 0 not found primary drive 1 not found gives me the option of F1...
This normally means that the Hard Drive is not recognized, and most likely can be attributed through a crashed hard drive. If it's not POSTing, then I think you need to look for loose cords/cables as well. That can cause the hard drive to not be recognized.
Jul 07, 2011 | Dell Dimension 3000 PC Desktop
Flat Panel Monitor Displays Message about No Signal, Signal out of Range, Sleep, or Power Save
You monitor can't pick the signal from the output video card, you need to remove the VGA cable and again put it back, but make sure that your PC isn't power on. After you have done this, reboot the system. You'll see that there is no more problem with the display. Sometimes this problem is caused by CPU overclocking, if the problem still persists, remove the BIOS battery and leave it outside for at least five minutes and put it back. That'll solve all the problems related to display. Good luck...
May 08, 2010 | HP Pavilion A6430F Desktop PC
VERIFYING DMI POOL DATA A DISK READ ERROR OCCURRED PRESS CTRL+ALT+DEL TO RESTART MESSAGE I GET EACH TIME I REBOOT
if this is always the messages you recieve you have a corrupt windows either cause by a virus or a failing device such as you hdd, try re installing the software or operating system that you are using check on the bios setup if your comp still detects your hardrive if so you have to run your installation disc to resolve the problem
Dec 07, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
HI no startup beep on my emachine and no signal onscreen
Get a new Hard Drive and plug it into your USB Port
Jul 05, 2008 | E-Machines eMachines Desktop PC
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SafeVIEW Baby Monitor Logo
47 people viewed this question
Top Samsung Baby Gear Experts
Dorel UK
Dorel UK
Are you a Samsung Baby Gear Expert? Answer questions, earn points and help others
