Question about GE Lands Phones
Would like to know where i can buy some more of these ge 4 line business phones model# 29451a -3 of our phones burnt out due to a fire in the underground stree we are on
  • 48 Answers
A good place to try would be buymebuyme
Posted on Jun 22, 2009
Runs fine going down road but when you engage blades to mow it starts to back fire but it will keep running
Make/Model/Year/Engine size, these are helpful for a more precise answer.
However, you are describing a backfire problem that occurs when the engine is placed under a load.
The major contributors to backfire under a load (and in general) are:
1.Bad fuel
2.Weak Spark
3.Poor Timing
4.Poor seal due to valve considerations (adjustment and wear).
So here are the fixes:
  1. Check for good spark and replace the plugs. UN-burnt fuel, due to weak spark, causes backfire in the exhaust.
  2. Weak spark may be due to coil problems or bad coil gap. Check coil gap.
  3. Change fuel to the highest octane you can buy. Old fuel looses octane and does not burn as hot. Do not store fuel for more than 3 months.
  4. If your engine has a flywheel key, it may be damaged. This will throw off the timing.
  5. Check the valve adjustment. A sticky, bent, or worn valve can cause backfire. Worst case you may have to do a valve job (have the valves and seats reground).
These are your first line, mostly easy, fixes for backfire.
Mar 15, 2015 | Garden
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
No dail tone for fax
HP just started a recall on these units due to a potential overheating and fire hazard. They have started a buy back program. Additional details can be found here:
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
Just thought you may need to know about this.
BuddyMc
Jan 19, 2012 | HP 1040 Plain Paper Inkjet Fax
Firing order for a 97 pontiac grand am se
For the 1997 Pontiac Grand Am:
I do not know if you have the 2.4L DOHC In-Line 4-Cylinder or the 3.1L V6. However I have included both below. I suspect based on the SE Model you have the 3.1L V6.
For the 2.4L DOHC In-Line 4-Cylinder:
Firing Order:
1-3-4-2
Cylinders:
..........(back).........
|...1....2....3....4...|
..........(front)
For the 3.1L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
|...1....3....5...|
_____________
|...2....4....6...|
......(front)
Ignition Coil Connections
_____..____...____
|..O..|..|..O..|..|..O..|
|.5..2|..|.3..6|..|.4..1|
Let me know if this helped.....
May 16, 2010 | 1997 Pontiac Grand Am
RCA Executive Series 4-line model# 25413RE3-A
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
May 08, 2009 | RCA 25413RE3 Corded Phone
Need to buy 2 more telephones compatible with the ones we have
Any 4 line analog phone will work. However intercom will only work on RCA
Mar 18, 2009 | Lands Phones
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
TReset for GE Pro Series Model 29451A
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Sep 10, 2007 | GE 25413RE3 Corded Phone
Lands Phones Logo
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
