Question about sonya Portable Compact Small Laundry Dryer Apartment Size 110vstainless Steel Drum Transparent Lid 8.8lbs Capacity/2.65cu.ft
Sonya Portable Compact Small Laundry Dryer Apartment Size 110vstainless Steel Drum Transparent Lid 8.8lbs Capacity/2.65cu.ft what kind of fuse does it use !!!
Sonya Portable Compact Small Laundry Dryer Apartment Size 110vstainless Steel Drum Transparent Lid 8.8lbs Capacity/2.65cu.ft what fuse does it use
What is the cubic feet of Kenmore refrigerator 253.77872509?
The fourth digit after the prefix usually indicates the refrigerator capacity. It probably has 27 cu. ft. capacity. (If it is a small apartment size fridge would be a 17 cu. ft. model.)
I hope this helps.
May 05, 2017 | Kenmore Refrigerators
Need user manual for Sonya compact dryer
Hi, could not find a users manual for sonya SYD-60E dryer so that I could order a thermal fuse, as the dryer would not run, however, I found a blog that suggested that Avanti, Sonja and Panda were made by the same manufacturer, I found a phone number for Avanti, ordered the thermal fuse for the only model that Avanti sells, which cost $10.00, and in about 10 business days the part arrived, we installed it in our Sonya dryer and our dryer works beautifully! Hope this helps
May 24, 2016 | Dryers
The belt will not stay on the pulley can someone help me
I put a thin spacer behind the tension pulley , just enough to correct the alignment.
Jan 19, 2016 | sonya Portable Compact Laundry Dryer...
How to thread the belt on the idle wheel and pulley without it coming off
Sheryl
should be doable as long as it does not have welded belt retainers,
if it has removable bolts or guards which help keep belt from falling off, remove these first. good luck
press the helpful button
the link below shows how to do it, but is not your model, hope it helps Dryer Not Spinning Whirlpool Kenmore Electric Dryer Repair Part 341241
Jan 18, 2016 | sonya Portable Compact Small Laundry Dryer...
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Samsung dryer will not start or light up.
Check to ensure that you have power to the unit. If you are sure, the next step would be to check the thermal fuse, as it is the most likely candidate. If you take the back panel off of the dryer, you'll see a small (about 1") piece of white plastic with two wires clipped to it. The plastic piece is the thermal fuse. You can try to jump the wires (bypassing the fuse) to test the unit. If that is the issue, you can get a new thermal fuse on Amazon.com for under $5.
I hope this helps. Good luck.
Oct 23, 2013 | Samsung DV50F9A6EVW 27" Electric Dryer...
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
DPGT750EC1WW
anyway...
GE Profile Harmony™ 7.3 Cu. Ft. Capacity King-size Electric Dryer with Stainless Steel Drum
Use and Care Manual
Quick Specs
Installation Instructions
hopes that helps...
Jan 26, 2008 | GE DBSR453EBWW Electric Dryer
sonya Portable Compact Small Laundry Dryer Apartment Size 110vstainless Steel Drum Transparent Lid 8.8lbs Capacity/2.65cu.ft Logo
44 people viewed this question
Top sonya Dryers Experts
Are you a sonya Dryer Expert? Answer questions, earn points and help others
