Question about HP DeskJet 3520 InkJet Printer
Won't print black and i just replaced my cartridges. My printer status report was unreadable . the ink delivery portion on the status report showed the 3 colors very clearly and the black bar was basically empty why is this happening
sauruman
  • 7 Answers
SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Posted on Feb 21, 2008
IB4G2008
  • 3587 Answers
SOURCE: New Ink cartridges registering as empty ...
how old is this one? And sometimes, those 'replacement' cartridges are anything but standard.
recycle your printer responsibly
Posted on Mar 17, 2008
landsend
  • 1066 Answers
SOURCE: color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
Posted on Mar 30, 2009
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
SOURCE: cannot print in black because yellow cartridge is empty ?
Take the "empty" cartridge out and shake it, and then reinsert it. I did that on my HP 8500 and it worked. The indicator light showed it was full.
Posted on Nov 01, 2010
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
How can i check which ink are out
Your printer should have come with a disk. This disk would have installed the necessary program that runs printing jobs, as well as keeps track of the ink level. Locate this program on your computer (may be under All Programs, Accessories under the Start Menu).
If not, Go into the Control Panel: (see below)
Above, you see "Hardware and Sound"; and below that shows "View Devices and Printers. Click on this. It will then bring you into the below dialogue box, of which shows any and all printers currently installed and which are being used. (see below)
Once you have located your printer here - (name etc). Go into your Start Menu: In the Search Box at the bottom type "programs"; look for the words "show which programs are installed on your computer", should be the fourth in the list. Below is what the list will look like. Find your printer here to ensure it's installed.
Once you have determined it's installed, you need to locate the printer program in your file system. Once you retrieve this, click it to open it. The program should allow you to view the ink levels. With most printers, when ink is low it will automatically open a dialogue box showing the ink levels for each cartridge. If you're printer is not equipped with this feature, then the only way to know if any need changed is when printing a document, and any color is not present.
I apologize for such a long response, as I wanted you to know how to access these files. If you are printing, and all colors appear to be present, without fading, or "blotchy" spots, then your cartridges are still good. You should be able to do a print test (calibration or alignment test) to determine this as well.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 27, 2011 | HP Officejet 6500 Wireless All-in-One...
When i refill toner it still show toner low.how sovle the problem
Good day.
First try to print a print status report. Here are the steps:
1.Push setup menu button, that would be the wrench icon. 2.Push the right button to navigate until you get to the Tools Menu 3.Tools Menu>Push button for Printer Status Report
This will give you the accurate ink levels on your printer. If it still shows low ink based on the printer status report, you have to reseat the ink cartridge and make sure the orange tape near the HP Logo on the ink cartridge has been peeled off.
If the report shows ink levels are fine, then that status report on the front panel is just a false report. Try powering off your printer and powering it back on again. As long as you don't have print quality issues, you should be fine.
Jun 20, 2011 | HP LaserJet CP1515n Printer
My TX550W ran out of Black Ink (T103) and I replaced it with a Genuine Epson Cartridge compatible with my printer (73N), My computer status monitor/ink check on the printer shows the black ink is now full...
Sometimes the ink does take a while to come from the cartridge to the print head. Performing 1 head cleaning procedure may fix this. But only do this once, anything after is just wasting ink. Also make sure no part of the air tab sticker has blocked the air hole in the cartridge. Have a look at the new one you have to find the hole. Its just under the sticker you take off before installing it into the printer.
I hope this helps Regards GM
Apr 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    How to reset ink level canon iP 2772??
    Download and run the ipTool to reset your ink level :
    http://www.mediafire.com/?nmj5nnzzjaw
    Features IP Tool software:
    • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
    • Print test feature to test nozzle on the cartridge.
    • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
    • Changing the delay value for drying.
    • Set the printer model manually.
    • Reading and reset EEPROM printer.
    • Reset counter and reset ink level on the color and black cartridges.
    Ink Level - shows the level ink:
    • BK - black cartridge.
    • CY - Cyan cartridge.
    • MG - Magenta cartridge.
    • YL - Yellow cartridge.
    • WM - Waste ink counter status.
    • WP - "additional" waste ink counter status.
    Port Name - displays the port where the printer installed.
    Port S / N - shows the serial number of the printer port.
    Power - shows the number of:
    • ON - inclusions printer.
    • OFF - to turn off the printer.
    Cartridge Info - Displays information status of:
    • CL - colored cartridge.
    Head Parking - displays the number of parking.
    Head Cleaning - shows the number how many time the cartridge cleaned.
    Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
    Cartridge Replacement - shows the number of cartridge replacements:
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 20, 2010 | Office Equipment & Supplies
    Replaced empty black ink cartridge, wont print black ink even after cleaning and aligning the printheads
    The head of your printer cartrige (black) are not detected by the printer because it was damage and need to be replace. So that no more black ink could print anyway.
    May 26, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
    Printing yellow for black
    Hi Jan,
    Can you confirm that you are using a CIS or non-HP cartridges with this printer?
    It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
    Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
    One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
    Hope this gives some clues and hopefully some ideas of a fix.
    Martin
    May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Printer head clogged
    Assuming that by "I have tried many times with the utilities" you mean you have tried many cleaning cycles, there may be other reasons than clogged nozzles. First ensure there is ink in the ink cartridge. Even though the Status Monitor (SM) may show there is ink, there may not be. The cartridge chip merely counts the number of ink shots the printer uses and reports this to the SM. Thus the ink remaining is merely an estimate and for a number of reasons can be wildly wrong. Change the black cartridge for a new one. If it still doesn't print, report back.
    Aug 26, 2008 | Epson Stylus Color 460 InkJet Printer
    HP DeskJet 3520 InkJet Printer Logo
    65 people viewed this question
    Seeker5211
    Seeker5211
