Question about Seiko Hc500 Protape 16' Electronic Tape Measure
Battery replace how do i install a battery
    Master:
  • 678 Answers
Small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
Posted on Dec 23, 2016
  • Vuk B Dec 23, 2016
    small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
How do I Replace the battery for my Michael kors mk-5758 watch
  • Remove back
  • Find battery in holder and identify type. Note mounting for reference during installation
  • Place watch and back in a plastic bag to prevent contamination while you obtain a replacement battery
  • Install new battery
  • Check operation
  • Install back
  • Set time etc.
Aug 30, 2016 | Michael Kors Watches
What is the battery that my mk 5590 watch needs?
  • Remove back
  • Find battery and identify type. Note mounting arrangement and polarity (place watch in plastic bag to keep out dust while replacement battery is being obtained)
  • Install battery
  • Check operation
  • Install back
Aug 17, 2016 | Watches
What size battery does a diesel dz7247 take?
Remove back
Find battery location and identify type. Note how it is installed.
You might as well leave the watch open while you get a replacement battery. I put mine in a snack/sandwich bag while it is open.
Install the replacement battery, check operation, and install the back
Aug 11, 2016 | Watches
Trying to remove the battery from my 2007 soltice
Hello robert.... Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | 2007 Pontiac Solstice Convertible
Where is the battery located?
Battery Replacement
Removal Procedure
Lower the vehicle.
Remove the battery.
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
Nov 28, 2010 | 2007 Pontiac Solstice Convertible
How to change battery
  1. Disconnect the battery ground (negative) cable from the battery. Refer to Battery Negative Cable Disconnection and Connection .
  2. Remove the RH fender diagonal brace. Refer to Front Fender Upper Diagonal Brace Replacement in Body Front End.
  3. Disconnect the battery positive cable terminal bolt from the battery.
  4. Remove the battery hold down retainer bolt (1).
  5. Remove the battery hold down retainer (2). Important: Do not tip the battery more than 40 degrees during removal.
  6. Remove the battery (3).
  7. Remove the battery insulator from the battery.
  1. Install the battery insulator to the battery.
  2. Install the battery (3) to the battery tray.
  3. Install the battery hold down retainer (2). Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Install the battery hold down retainer bolt (1). Tighten
    Tighten the battery hold down bolt to 18 N·m (13 lb ft).
  5. Connect the battery positive cable to the battery. Tighten
    Tighten the battery positive terminal bolt to 15 N·m (11 lb ft).
  6. Install the RH fender diagonal brace. Refer to Front Fender Upper Diagonal Brace Replacement in Body Front End.
  7. Connect the battery negative cable to the battery. Tighten
    Tighten the battery negative terminal bolt to 15 N·m (11 lb ft).
Nov 11, 2010 | 2000 Chevrolet Monte Carlo
Need procedure to remove and replace the battery in a 2006 PT Cruiser
BATTERY
GASOLINE ENGINE
REMOVAL
WARNING:
  • TO PROTECT THE HANDS FROM BATTERY ACID, A SUITABLE PAIR OF HEAVY DUTY RUBBER GLOVES SHOULD BE WORN WHEN REMOVING OR SERVICING A BATTERY. SAFETY GLASSES ALSO SHOULD BE WORN.
  • REMOVE METALLIC JEWELRY TO AVOID INJURY BY ACCIDENTAL ARCING OF BATTERY CURRENT
  1. Make sure ignition switch is in OFF position and all accessories are OFF.
  2. Open hood.
  3. Remove the air cleaner housing.
  4. Disconnect and isolate the battery negative cable then the positive cable.
  5. Loosen bolt (4) and retainer (1) that holds the battery down to the tray.
  6. Lift battery out of battery tray and remove from vehicle.
  7. Remove thermal guard (if equipped) from battery.
CAUTION: Vehicles equipped with the turbocharged engine use a unique battery hold down. If the replacement battery is not identical, in size to the original, it may be necessary to use non-corrosive spacers on top of the hold down retainer to properly secure the battery in the battery tray.
When replacing battery, the thermal guard MUST be transferred to the new battery (if equipped).
  1. Install battery in vehicle making sure that the thermal guard (if equipped) is present and battery is properly positioned on battery tray.
  2. Install battery hold down hardware (1), (2), (3) and (4) making sure that it is properly positioned on battery. Torque clamp to 12.5 N.m (110 in. lbs.) .
  3. Install battery cables on battery posts. Install battery positive cable first.
  4. Torque clamp nuts to 12.5 N.m (110 in. lbs.) .
  5. Install air cleaner housing.
  6. Close hood.
  7. Verify proper vehicle operation.
Jul 15, 2010 | 2006 Chrysler PT Cruiser
Turn-on woes My TI83 will not turn on. Batteries new and installed correctly. What gives? Khumalo
Take out the AAA batteries and hold the on/off key for thirty seconds. Replace the batteries and it should come on. If it doesn't remove the backup battery and the AAA batteries and hold the on/off key for another 30 seconds. Replace all batteries and turn it on again.
Oct 13, 2008 | Texas Instruments TI-83 Plus Calculator
Seiko Hc500 Protape 16' Electronic Tape Measure Logo
182 people viewed this question
Top Seiko Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Seiko Measuring Tool and Sensor Expert? Answer questions, earn points and help others
